Mclaren MCL40
SilviuAgo
161
Re: Mclaren MCL40
Ahead of the BritishGP, a look back at McLaren's AustrianGP update:
The team revised the Rear Brake Duct Inlet to improve local flow conditioning, targeting a direct gain in aerodynamic load around the rear corner. Look at the geometry changes (arrows)!
source: nicolas carpentiers
SilviuAgo
161
Re: Mclaren MCL40
MCL40 rear suspension (Bracelona pics tks to Xavi)
SilviuAgo
161
Re: Mclaren MCL40
McLaren at Silverstone:
Loos like the "McLarena wing":) Interesting choice to run it considering that will be only one FP due to sprint weekend schedule.
Macklaren
Macklaren
Re: Mclaren MCL40
SilviuAgo wrote:
02 Jul 2026, 13:31
https://pbs.twimg.com/media/HMNs5JyW0AA ... name=large
if they actually run it, it will be very encouraging and indicate that the snafu last week was only an install issue rather than something design related
f1rules
f1rules
635
Re: Mclaren MCL40
i know this guy posted on twitter, but as far i know, this is not the maca rw. The actuater is completely wrong
SilviuAgo wrote:
02 Jul 2026, 13:31
https://pbs.twimg.com/media/HMNs5JZW0AE ... name=large
https://pbs.twimg.com/media/HMNs5KCXoAA ... name=large
SilviuAgo
161
Re: Mclaren MCL40
SilviuAgo wrote:
01 Jul 2026, 16:38
https://pbs.twimg.com/media/HMJYdMgXEAA ... name=large
Taking the Barcelona photo, Craig made a comment regarding the nice view of the top 'wishbone' on the Mclaren, underline the use of a multilink setup. So there are two separate top arms, which will affect both geometry and aerodynamics.
SilviuAgo
161
Re: Mclaren MCL40
f1rules wrote:
02 Jul 2026, 14:57
SilviuAgo wrote:
02 Jul 2026, 13:31
Multiple sources indicate the MCL40 prepared for the new RW. And imo it looks like "a refresh version" to the one they tried to use in Austria. Maybe they found out the initial solution for the actuator (from Austria) is not the ideal one and at Silverstone they try another iteration.
Macklaren
Macklaren
Re: Mclaren MCL40
I don't know but that actuator looks really....tall?
If the wing is going to swing enough to clear it, our opening may be even larger than RBR?
venkyhere
44
Re: Mclaren MCL40
Macklaren wrote:
02 Jul 2026, 17:06
Regardless of actuator height, the macarena state of the wing is anyway going to keep the upper flap 'behind' the actuator, because the rotation axis has to be closer to the top/rear edge of the flap, rather than the bottom/front edge.
