Mclaren MCL40
SilviuAgo
165
Re: Mclaren MCL40
Ahead of the BritishGP, a look back at McLaren's AustrianGP update:
The team revised the Rear Brake Duct Inlet to improve local flow conditioning, targeting a direct gain in aerodynamic load around the rear corner. Look at the geometry changes (arrows)!
source: nicolas carpentiers
SilviuAgo
165
Re: Mclaren MCL40
MCL40 rear suspension (Bracelona pics tks to Xavi)
SilviuAgo
165
Re: Mclaren MCL40
McLaren at Silverstone:
Loos like the "McLarena wing":) Interesting choice to run it considering that will be only one FP due to sprint weekend schedule.
Macklaren
Macklaren
Re: Mclaren MCL40
SilviuAgo wrote:
02 Jul 2026, 13:31
https://pbs.twimg.com/media/HMNs5JyW0AA ... name=large
if they actually run it, it will be very encouraging and indicate that the snafu last week was only an install issue rather than something design related
f1rules
f1rules
635
Re: Mclaren MCL40
i know this guy posted on twitter, but as far i know, this is not the maca rw. The actuater is completely wrong
SilviuAgo wrote:
02 Jul 2026, 13:31
https://pbs.twimg.com/media/HMNs5JZW0AE ... name=large
https://pbs.twimg.com/media/HMNs5KCXoAA ... name=large
SilviuAgo
165
Re: Mclaren MCL40
SilviuAgo wrote:
01 Jul 2026, 16:38
https://pbs.twimg.com/media/HMJYdMgXEAA ... name=large
Taking the Barcelona photo, Craig made a comment regarding the nice view of the top 'wishbone' on the Mclaren, underline the use of a multilink setup. So there are two separate top arms, which will affect both geometry and aerodynamics.
SilviuAgo
165
Re: Mclaren MCL40
f1rules wrote:
02 Jul 2026, 14:57
SilviuAgo wrote:
02 Jul 2026, 13:31
Multiple sources indicate the MCL40 prepared for the new RW. And imo it looks like "a refresh version" to the one they tried to use in Austria. Maybe they found out the initial solution for the actuator (from Austria) is not the ideal one and at Silverstone they try another iteration.
Macklaren
Macklaren
Re: Mclaren MCL40
I don't know but that actuator looks really....tall?
If the wing is going to swing enough to clear it, our opening may be even larger than RBR?
venkyhere
44
Re: Mclaren MCL40
Macklaren wrote:
02 Jul 2026, 17:06
Regardless of actuator height, the macarena state of the wing is anyway going to keep the upper flap 'behind' the actuator, because the rotation axis has to be closer to the top/rear edge of the flap, rather than the bottom/front edge.
f1rules
f1rules
635
Re: Mclaren MCL40
Im sorry, but exactly that post youre referring to, i challenged and he agreed. Im Michael Rosquist in that twitter post.
There is not multiple sources suggesting the macarena wing is back. Can be they will bring, but! the one photographed so far, is not it
SilviuAgo wrote:
02 Jul 2026, 15:23
f1rules wrote:
02 Jul 2026, 14:57
SilviuAgo wrote:
02 Jul 2026, 13:31
https://pbs.twimg.com/media/HL4Om7kXoAA ... name=large
michl420
michl420
Re: Mclaren MCL40
https://pbs.twimg.com/media/HKmDHCcXEAA ... name=large
Is that gold-foiled bulge near the exhaust a part of the fuel tank?
Re: Mclaren MCL40
michl420 wrote:
03 Jul 2026, 07:00
The fuel tank is all within the safety cell, behind the driver and below the roll hoop. That gold foiled item is perhaps part of the cooling system as it appears to have a bleed tube attached to it.
SilviuAgo
165
Re: Mclaren MCL40
McLaren has revised the floor board, now the vertical element has an opening that separates the lower part creating a cut, (Blu).
Moreover the main profile of the FB now features a softer and less squared profile (red)
And according to Craig, one of McLaren's BritishGP update is a mod to the face of the brake inlet scoop. A 3D printed part with wire debris fences. The top inner corner it's curve downwards, reducing the inlet area and directing more flow around the back of the tyre.
McLarenF1 introduced this new Front Brake Duct design for the primary reason of performance and flow conditioning. This updated design results in improved flow conditioning and a gain in aerodynamic load.
Re: Mclaren MCL40
SilviuAgo wrote:
03 Jul 2026, 12:59
https://pbs.twimg.com/media/HMS0LURWIAA ... name=small
https://pbs.twimg.com/media/HMS6mG3XAAA ... =4096x4096
https://pbs.twimg.com/media/HMS6mHjXQAA ... name=large
https://pbs.twimg.com/media/HMS0CF9XcAA ... =4096x4096
Lot of refinement work being done. Maybe mclaren getting happier with overall flow and it's about finding those improvements
SilviuAgo
165
Re: Mclaren MCL40
03 Jul 2026, 14:59
I think they try to squeeze all is possible from this MCL40 iteration. Zak said now on f1tv that some big upgrades are coming next races, and they are very confident about it.
McLaren's floor update includes a subtle change to the floorboard.
