Toro Rosso STR13 Honda
tcooper27
tcooper27
Re: Toro Rosso STR13 Honda
PhillipM wrote:
Fri May 04, 2018 5:12 pm
Weight distributions are fairly tightly fixed, wheelbases aren't too dissimilar for weight transfer and braking effects, discs are fairly cold from the huge amount of air they just took in so heat isn't too much of an issue - it builds up more in the twisty section.
That may also contribute to a problem. Carbon brakes work best above a certain temperature. They're pretty worthless cold. Much like tires, they have an optimum working range.
designf1
designf1
75
ScrewCaptain27
575
New mirror fairing:
Via AMuS
- Serj Tankian
Via AMuS
F1NAC
176
Ouch
Singabule
Singabule
34
Hartley survive this crash is miracle, let alone a PU. Lucky this is the old one
RZS10
229
Was the crash so severe or is the back end of the STR flimsy (potentially compromised bc of late PU change) ?
Singabule
Singabule
34
RZS10 wrote:
Sat May 12, 2018 12:09 pm
No, they design the mounting to be pop up if there is a heavy shunt, hence reduce the energy that is potentially deadly to safety cells
iichel
iichel
27
Poor car
right click -> "open in new tab" for more size
amho
How weight distributions are fixed? fixed by rules or you mean that all teams have closed to optimum design which means similar weight distributions? and even if static weight distribution is fixed by rules then different suspension compression during braking affects weight distribution (dynamic w.d.) and suspension geometry and in result tire contact and braking ability. agree?
There is no Might or Power except with Allah.
ScrewCaptain27
575
amho wrote:
Sat May 12, 2018 7:29 pm
Fixed by regulations, up to 55% back I believe
- Serj Tankian
I'd never seen an F1 car crash like this. It was painful! :(
Singabule
Singabule
34
ScrewCaptain27 wrote:
Sat May 12, 2018 8:01 pm
No. 53 at back, 47 at front. Fixed for all teams based on pirelli request in 2013. Thats why we have limousine cars since they need to strach the back of the car to meet the regulation requirement or put heavy balast on FW. Then compare it to indy and good old v10 days and you get the idea
vortexrulez
vortexrulez
Hino
Hino
123
Can't be surprised, its the gearbox and rear suspension. Although they did have to modify the gearbox to bolt on the Honda PU, I wonder if it means anything?
