McLaren MCL33
Re: McLaren MCL33
I have thought the same thing. Looks "under-devolped" to other teams.
Maybe they decided to stick with it (works well) while working on fixing their speed problems.
Xero
32
Re: McLaren MCL33
M840TR wrote:
22 Jun 2018, 23:22
Anyone else notice how big the brake ducts are compared to others?
McLaren have a blown front axel, so a section of that inlet is for that rather than brake cooling. Not sure if any of those other teams you showed do the same, doesn't look like it from the photos.
M840TR
M840TR
313
Re: McLaren MCL33
Xero wrote:
23 Jun 2018, 13:17
M840TR wrote:
22 Jun 2018, 23:22
I think everyone has a blown axle
Mattchu
49
Re: McLaren MCL33
M840TR wrote:
23 Jun 2018, 13:20
Mercedes definately dont..
roon wrote:
22 Jun 2018, 22:32
Illustrates relationship between FW height and the forward edge of the plank/t-tray. Although not apparent in this image, the FW footplate and floor/plank are parallel and raked at the same angle, by decree. Sometimes the rear edge of the FW footplate pivots downward under aero loading.
Could you explain what you mean by this because to me it looks like the front wing is parallel to the floor unless under load whereas the front of the plank [t-tray area] is whatever the rake angle the car is.
Probably not a great one but:
One
One
Re: McLaren MCL33
This down fall of McLaren's performances makes me think about their developments.
1. Is the nw nose working? Cape and air flow around/through the nose?
it does look as though the nose do not deliver the performance.
DiogoBrand
73
Re: McLaren MCL33
One wrote:
24 Jun 2018, 05:47
Could you please show us on what data you based your conclusion that McLaren's bad results are linked to their introduction of a new nosecone? It would certainly add a lot to the discussion.
BrunoH
BrunoH
Re: McLaren MCL33
well i guess results speak for them selfs, since the new aero kit turned the car from a dog to go down the straights to a dog all around the circuit....
Andres125sx
Re: McLaren MCL33
ollandos wrote:
22 Jun 2018, 17:18
socking to watch this car on track......my view ...the car is too sort too heavy with very bad weight balance and managment ...looks like to heavy at the middle part of the car and that cut the car too 3 sector ..and not on 2 ..(axles)
mclaren must build brand new car ...longer with must possible less weight and center of gravity lower and much more to the rear of the car ....the mcl33 looks like a car with 3 axle ..the 2 majors on the front and middle ..and the real rear like helping wheels of baby bicylce ..if you remember any one owner of this baby bicycles you cant go fast ..because ..the small wheel diameter ..limit the big one ...the problems of the car is something similar ...you can not go faster even x more power or x more downforce ...bigger wheelbase move weight at the back and lower ...remove us must possible weight from the middle part of the car ... :idea: :idea:
Hey that´s brilliant, a car with only two axles, but no Z, will solve all of their drag problems :mrgreen: :lol: :lol: :lol:
:roll:
iichel
iichel
Re: McLaren MCL33
Broken upper wishbone for the #14 McLaren
roon
roon
412
Re: McLaren MCL33
iichel wrote:
24 Jun 2018, 21:22
https://i.imgur.com/fj6SEc4.jpg
What lap was that?
Re: McLaren MCL33
Last lap I believe.
But it's interesting, how would that have happened?
holeindalip
holeindalip
Re: McLaren MCL33
wesley123 wrote:
24 Jun 2018, 21:59
Last lap I believe.
Hitting curbs maybe, happened a few times in Austria a few years ago to a few teams
Big Tea
99
Re: McLaren MCL33
wesley123 wrote:
24 Jun 2018, 21:59
Last lap I believe.
A couple of laps before the V safety, the commentator said Alonso had pitted for softest tyres to try for fastest lap. Probably had a mis-hap trying too hard.
iichel
iichel
Re: McLaren MCL33
roon wrote:
24 Jun 2018, 21:57
iichel wrote:
24 Jun 2018, 21:22
What lap was that?
IIRC it was on (his) lap 50
JonoNic
Re: McLaren MCL33
wesley123 wrote:Last lap I believe.
Isn't that the same wheel side that Vettel tapped?
Always find the gap then use it.
