McLaren MCL34
Re: McLaren MCL34
I can can see the difference but does it really do anything aside from give more structural strength ? just looks like a coating to make it thicker.
M840TR
M840TR
313
Re: McLaren MCL34
diffuser wrote:
20 Jun 2019, 18:21
...there are mechanical components underneath.
Re: McLaren MCL34
Via AMuS
Re: McLaren MCL34
M840TR wrote:
20 Jun 2019, 18:26
diffuser wrote:
20 Jun 2019, 18:21
we sure of that or is that an assumption ?
trinidefender
trinidefender
317
Re: McLaren MCL34
diffuser wrote:
20 Jun 2019, 18:21
On the pushrod? Of course. The pivot point on the pushrod has been moved inboard. Before the pivot point was close to the upright which means that it's close to the vertical axis of rotation = when the wheel is steered there is very little ride height change.
Now the pivot point for the end of the pushrod has been moved inboard to the top of the thick portion sticking out of upright. This puts it far away from the axis of rotation of a wheel being steered. As the wheel is turned on the steering axis it pulls the wheels up, ergo the front ride height drops.
It is this dropping of the front ride height that increases front wing performance (read downforce) and improves front end performance.
Re: McLaren MCL34
M840TR wrote:
20 Jun 2019, 11:14
makecry wrote:
20 Jun 2019, 09:34
M840TR wrote:
20 Jun 2019, 09:19
If the Pushrod-on-Upright feature works - and it probably will - then this could be somewhat of a game-changer.
Can you hmm.. dumb it down a bit?
Are you asking for an explanation? If so, then it works by lowering the outer wheel & raising inner one mid-corner. This reduces front ride height and increases tyre contact surface. Therefore more grip.
Btw, Williams introduced the system in Canada and even the beleaguered FW42 improved its performance.
The Video I saw, it was hard to tell if the ride height changed. The camber definitely did. On the left hand turn, the bottom went out (increase of negative camber).
Re: McLaren MCL34
The camber is nothing to do with the pushrod.
ALO_Power
ALO_Power
Re: McLaren MCL34
Are there any changes on the bargeboards? I'm not sure if those elements that were conecting them together where there before.
Re: McLaren MCL34
Is that pullrod cover on the rear suspension just not fitted down or does it really leave a split trailing edge like that? :wtf:
Can't see how it'd be legal if the latter?
Re: McLaren MCL34
PhillipM wrote:
20 Jun 2019, 19:10
Reminds me of the 2014 suspension arms.
Re: McLaren MCL34
PhillipM wrote:
20 Jun 2019, 19:06
Maybe not but a change is camber is occurring here. Looks like the bottom is being pulled in. Could be the Anti-roll bar pulling that in.
Re: McLaren MCL34
That's just normal suspension geometery - as before, nothing to do with the pushrod.
roon
roon
412
Re: McLaren MCL34
To expand on PhillipM's comment, steering angle combined with caster/kingpin angle can make a cambered wheel appear to lose camber. Shock absorber connections do not influence this.
https://i2.wp.com/wallup.net/wp-content ... ustang.jpg
https://newsfirst.sunlive.co.nz/assets/ ... g-Lead.jpg
https://files.driftmasters.gp/wp-conten ... 6P6415.jpg
trinidefender
trinidefender
317
Re: McLaren MCL34
diffuser wrote:
20 Jun 2019, 20:03
PhillipM wrote:
20 Jun 2019, 19:06
https://www.youtube.com/watch?v=ZrWYnAUsDAU
No it can't be the anti-roll, the camber is controlled by the suspension geometry. I.e. The angle, length and placement points (on the attachments on the chassis and upright) of the wishbones. The anti-roll bar is attached to the pushrods which only have control over the vertical displacement of the upright (and therefore tyre).
More important in that video is that you can see as the steering lock is applied the wishbones rise squatting the front of the car.
N.b. I guess there may be some small effects in toe but definitely nothing significant like we are observing.
M840TR
M840TR
313
Re: McLaren MCL34
AMuS
