2021 car comparison thread
Re: 2021 car comparison thread
A521 Vs MCL35M
Is it better to align the T-cams or the lights/diffusers in your opinion?
2021RB rear-end vs 2019 RB rear-end (2021 AT02)
SiLo
130
Blackout wrote:
16 Mar 2021, 12:00
A521 Vs MCL35M
https://i.imgur.com/AurEiFC.jpg
https://i.imgur.com/NwqHTyN.jpg
Wait does the McLaren have brake duct winglets below the step plane?
Felipe Baby!
jjn9128
769
SiLo wrote:
17 Mar 2021, 17:39
Blackout wrote:
16 Mar 2021, 12:00
A521 Vs MCL35M
Yes. The brake ducts/winglets are defined relative to the wheel hub not the reference plane.
#aerogandalf
Via @NicolasF1i
SiLo
130
Red Bull following the Mercedes route trying to clear the air above the diffuser. Nice to see them trying a different method though of just raising the suspension. I'm guessing that's easier than doing what Mercedes did.
Felipe Baby!
But Merc still has the cleanest cocke bottle area, thanks to it's 'invisible' pull rod (pink) that is mounted so high that most of it can hid behind the bodywork and avoid the way that goes to the diffuser.
Ferrari is similar in this aspect since a couple of seasons, their pull rod is also mounted quite high on the gearbox... but obviously the lower wishbone front arm is still in the way.
RB and MCL is the other way around.
AM is obviously the same as Merc now.
I wonder if teams will copy the complete Merc geometry in 2022
Would mounting the pushrod higher make it shorter and thus lower motion ratios giving you a smaller tuning window? In McLaren and RBR's case they have very long pushrods and large motion ratios giving them more fine tuning control over damping and spring rates.
Blackout wrote:
18 Mar 2021, 17:39
https://i.imgur.com/4XYJjCn.jpg
Perhaps RB felt it was worth the compromise of having the pullrod in the way by moving the suspension mounting down low allowing a more aggressive undercut at the rear of the car.
OO7
OO7
171
godlameroso wrote:
18 Mar 2021, 19:02
Blackout wrote:
18 Mar 2021, 17:39
I was about to post the same. RB perhaps make up for it with the narrower gearbox casing.
SiLo
130
They have run that pullrod design for years now. It's always been connected at the floor like that.
Felipe Baby!
Jolle
Jolle
godlameroso wrote:
18 Mar 2021, 18:59
The length of the pushrod doesn’t matter, the angle does. Both RedBull and McLaren have their pushrod so far away from the actual motion (by being swept forward) that there will be difficulty to have the same level as precision as a pushrod that is more in line with the axle.
kfrantzios
kfrantzios
46
Different intake configurations
jjn9128
769
There's so much internal ducting, no wonder these cars are so heavy :lol:
#aerogandalf
DarthPlagueisTheVise
42
From Imola
Technical Noob
