2017 Australian Grand Prix - Melbourne, 24 - 26 March
Locked
Phil
66
Contact:
Re: 2017 FORMULA 1 ROLEX AUSTRALIAN GRAND PRIX Fri 24 – Sun 26 Mar 2017
Vasconia wrote:Mercedes has been particularly dominant on this track so if we see Ferrari close there will be some hope for this season, if they are even ahead 2017 could be a great season.
Melbourne isn't a typical "race track". I don't think you will see much correlation between this and the 2017 season. Yes, the quickest car will be ahead, but if the cars are closer matched (hasn't been the case for a few seasons now), the result here will not necessarily correlate to what will follow after.
#Team44 supporter
Vasconia
Yes I know, but traditionally Mercedes has always been quite dominant here, I meaned that perhaps a change could mean that the others are closer.
Last year Ferrari matched Mercedes on race pace in Melbourne.
Vasconia
But their qualy was much worse. During some races it happened something similar, Ferrari was clearly behind in qualy while in race pace things were closer.
Of course, but ultimately it's the race where you get the points. Qualy is important, but due the show and emphasis on it people tend to forget how quickly a hard worked qualification spot can be undone by a bad start. And we are going to see a whole lot of bad starts up and down the field this year due further regulation changes we have in that regard, meaning race pace will become even more important then last year.
Vasconia
turbof1 wrote: Of course, but ultimately it's the race where you get the points. Qualy is important, but due the show and emphasis on it people tend to forget how quickly a hard worked qualification spot can be undone by a bad start. And we are going to see a whole lot of bad starts up and down the field this year due further regulation changes we have in that regard, meaning race pace will become even more important then last year.
Indeed, though if you make a good start it will be difficult to be overtaken due to the new regulations, cars,etc.
Anway, I hope race pace becomes enough important to see a second/third row car fighting for the victory.
Hamilton should be worried with those new regulations taking into account his problematic starts in 2016.
FLuidd
-13
Ferrari 1 2 in qualifying and 1 2 in race followed by mercedes 3 4.
GoranF1
155
Contact:
Mclaren Mercedes podium.
notsofast
Hamilton early DNF. Easy win for Vettel. Poor start by VES who then politely stays behind RIC, because it's his home race. BOT and RAI tussle for the other two podium places. And in the end, we don't learn a whole lot about the pecking order.
dren
226
Hamilton pole, Hamilton victory. Mercedes and Ferrari lap the field. The race is a procession. Max tries to force a pass on Ricciardo and crashes both of them out of the race. Both Mclarens finish.
Honda!
Singabule
Both RBR DNF, Vettel DNF, Hamilton broke his wing, Stoffel finish 2 position higher than Alo, magnussen finish 6th.
Updated the OP with a more detailed weather forecast.
ENGINE TUNER
25
turbof1 wrote:Last year Ferrari matched Mercedes on race pace in Melbourne.
Whatever gave you that idea? VET was on soft(or was it supersoft) after the red flag and ROS was on mediums and VET still could not pull a gap. The only reason it looked close in Australia last year was because of the poor start by both Mercs and then ROS running over HAM's front wing.
Ferrari did NOT match Merc's race pace last year.
Just rewatched the race yesterday
In regards to the 2017 race, it seems we have moved from tire limited race pace to a fuel limited race pace. Just might be a lot of lift and coast. Qualifying pace will be at an utmost premium this year .
GPR-A duplicate2
64
Correct. Having lost the start, Lewis was stuck behind Sainz for a large part of the race and was unable to overtake in the tight confines of Albert Park, which allowed Nico to run conservative. Importantly, Nico was managing overheating breaks that was almost killing the tires at later part of the race. As per Toto, they were afraid that, the tires might blow out. The fact that Merc maintained the qualifying gap over Ferrari for pretty much all season, tells that, whatever race pace difference that they maintained over Ferrari over the season, was there in Melbourne too, but got masked because of variety of situations going against them. I bet, if Lewis would have got a straight forward start, he would have disappeared without a trace.
ENGINE TUNER
25
GPR-A wrote:Correct. Having lost the start, Lewis was stuck behind Sainz for a large part of the race and was unable to overtake in the tight confines of Albert Park, which allowed Nico to run conservative. Importantly, Nico was managing overheating breaks that was almost killing the tires at later part of the race. As per Toto, they were afraid that, the tires might blow out. The fact that Merc maintained the qualifying gap over Ferrari for pretty much all season, tells that, whatever race pace difference that they maintained over Ferrari over the season, was there in Melbourne too, but got masked because of variety of situations going against them. I bet, if Lewis would have got a straight forward start, he would have disappeared without a trace.
I think it was VES that HAM was stuck behind for the first stint. After the red flag, Ham was behind Sainz, but was able to eventually get past him, and was behind VES again for a couple lasts until VES pitted.
I heard nothing of overheating brakes.
Yes, either of the Mercs ahead would have significantly gapped the Ferraris, but it was telling how ROS was unable to pass RAI.
Locked
