[KVRC ~ish] CCE LMP01
machin
162
Re: [KVRC ~ish] CCE LMP01
Probably a good way.. I presume that makes it a lot quicker?
RicME85
52
Can get a figure in 5 mins. Obviously isn't accurate but can get an idea as the numbers are definitely different for each airfoil and AoA
RicME85
52
Current rear wing profile:
Variante style front wing airfoil:
That close enough downforce level? :lol:
machin
162
Not bad! So is the Variante style front wing the 3 (or is it 4?) element one? And do you have it positioned the same height above the ground as the other wing (just checking it isn't benefiting from ground effect...)?
RicME85
52
It's one of the airfoils taken from the whole car cross section Chris did in an early round.
I have scaled it to fit the rule box for the rear wing and place it so the trailing edge is on the very back edge of the rear wing reg box (trailing edge is on the line between the rear top corners of the RWEPs).
Both this and the airfoils I was using are placed in the same place for this test ie along that line
machin
162
Ok...So just checking I understand: the first result is the aero data for the current twin element wing(?)... And the second one is a single element wing based on one element from Variante's cross section?
RicME85
52
Yes with the Variante one with an AoA that produces a similar level of downforce to the original twin element.
machin
162
Cool, well you should be pretty safe to carry that Cd.A saving (0.06) directly over to your last full car model... So that should bring your total car down to a Cd.A of about 1.30... And an overall L:D of 3.85!
...are you planning to try a few more different element shapes?
RicME85
52
Yes definitely. I tried one but couldn't get the downforce from it.
Went looking for high efficiency wings but got caught in a world of profiles :S
variante
133
Could you show a cross section of the wing you're talking about? (possibly showing pressure distribution)
variante
133
The one inspired by my airfoils
RicME85
52
I can but it won't show a lot as I have only run the 'test' setting in OCCFD to get some vase figures whilst working out the AoA.
Now that I have got an idea I can use the usual OCCFD setting to get a proper set of figures.
Also have the issue of legality as I changed the AoA but not kept the airfoil within the cross section rule for the rear wing so need to work on that.
RicME85
52
Found something very interesting regarding OCCFD.
This is a set of figures obtained with the Stable AWS setting:
This is the same wing STL file but using just the Testing local setting:
Figures are all but identical, one setting took hours with a fine mesh, the other took less than 5 minutes with a coarser mesh.
machin
162
Maybe because it is a small object, with relatively simple geometry?
