Parts supplied with this stage were: Instrument panel rear (1), Instrument panel front (2), green data registration button & red data registration button on sprue (3), red fire extinguisher & black brake balance adjuster on sprue (4), various switches on sprue (5), mixture/turbo boost controls x 2 (6), fuel filler valve (7), fuel filler valve housing (8), gear linkage bearing housing (9), decal sheet (10). None of these parts were needed for this stage, annoying but ohh well.
And some close up photos of some of the smaller and more detailed parts:
Parts needed from previous stages were:
- Left and right turbocharger air intake assemblies (Stage 20)
- Hose B (Stage 47)
- Wire A (Stage 51)
- Left and right wastegate cooling pipes front (Stage 56)
- Monocoque assembly (Stage 63)
Firstly, 64.1. Fitting the wastegate pipe fronts to the turbcharger air intakes. Firstly the left wastegate cooling pipe front was glued to the left air intake.
Following this, the wastegate cooling pipe was glued onto the wastegate cooling pipe front.
And then repeated for the right hand side. No issues here to report, all straight forward enough.
There was a stage now (64.2) that had the air intakes temporarily fitted to the monocoque assembly and then immediately removed. I've not photographed this as it will be shown during the main assembly.
Onto 64.3, the underbody middle and rear were both removed, as was the engine block from the monocoque. Pictured below to show some of the exhaust detailing.
The eagle eyed among you will have noticed that the oil filter joint on the engine block that I lost and replaced with my own has been replaced again. This is because, as I think I've mentioned prior I tend to do these builds in one day when I get the issue as I don't have a lot of space so have to do the build and then pack up all my bits and bobs until the next stage. So anyway, after spending ages carving and melting a bit of plastic into an oil filter joint I ended up finding the original that I had knocked off on the floor and glued it back on. God damn that's frustrating. Was probably more annoyed when I found it than when I lost it haha. But, I digress.. so onwards with stage 64.
Following this little detour, 64.4, fitting the hoses. Firstly 2 lengths of 40mm wire, 2 x 35mm wire, 2 x 50mm hose & 2 x 45mm hose. These were combined in the following ways: 40mm wire into 50mm hose & 35mm wire into 45mm hose.
One end of one of the 40mm/50mm hoses was glued to the pin of the oil filter joint on the engine block.
And the other end was bent around and glued behind the turbocharger.
Of note was that the hose was not supposed to touch the exhaust pipe, I'm assuming on the real thing this was something to do with high temps.
This was repeated for the other side.
Next up one end of the 35mm/45mm hoses was glued to the nozzle on the inside of the turbo charger.
This was bent around and under and the other end was glued to the blue pin on the side of the engine block, shown here from the front.
This was repeated for the other side, shown from the bottom here to see the different hoses.
And from the fronts.
The most annoying bits of this stage were, as was the case with other hoses and wires the wires would occasionally push through the fabric hose material. This was quite easily rectified though by trimming the wire where needed, or pushing it back into the hose. There was also some problem with the sealing of the hose, when I cut them from the overall length I sealed the ends with adhesive to stop them fraying, there was a couple instances where the ends had closed up so I had to trim about 1mm off and then enlarge the ends. Not a massive catastrophe all things considered.
And that's it for this week, thanks for reading as usual.
I'm currently planning how to display it, so I'd appreciate your input below, basically I'm deciding weather to make a scale replica of a track section and have the model displayed in a dynamic pose, probably as if it's oversteering, might also get a 1:8 model senna as well or at least a helmet.
My other option is just a standard clear plastic display case with wooden plinth and plaque. As I said I'd appreciate your thoughts below so please comment with any ideas or votes for which idea you think is better.
Cheers,
Alex
