2025 Aston Martin | Aramco F1 Team
Re: 2025 Aston Martin | Aramco F1 Team
18 Aug 2025, 22:07
No team will be allowed to setup shop the way Red Bull have. That is one and done. Red Bull are lucky that they got in when they did. They will never allow it again. Zak Brown has spent years railing against it. I'm surprised that Macklaren was not aware.
Ok.
I can see how Aston would be interested in having another team to run the Honda PU. Don't think the gossipers could have a clue how far the depth of RBR model they want to model. It's Gossip, the deeper you go, the further from what was whispered you're getting.
Macklaren wrote:
18 Aug 2025, 20:24
diffuser wrote:
18 Aug 2025, 20:04
Macklaren wrote:
18 Aug 2025, 18:31
Very interesting! With the Lagonda brand failing to take off, wonder if this could be a way for Honda to reenter the sport as a "works" team and get the 12th spot on the grid
Well Honda is a works team in 2025 and will continue to be in 2026. That will not change. The part of "in the Red bull model" and them dictating who would run it, suggests Honda would have little more to do with it than PU & sponsor. Otherwise, the Gossip would have read that Honda was looking at buying a F1 team, which it doesn't say. Anyways, it's gossip.
I don't understand the "Lagonda brand failing" statement. It is my understanding that Aston martin have a long term F1 branding deal in place with AM F1, if that's what you're referring to. That isn't going anywhere, is my understanding.
I meant if AMR want a B-team, it cant be called Aston Martin also? God knows how much trouble Red Bull has had with naming their B-team. One alternative could have been to use the other road car brand in the AMR stable (Lagonda) but that is probably not happening since Lagonda has failed to take off on the road car side. So an AMR B-team could be Honda branded with Honda engine and Honda drivers but effectively run by AMR/Alonso (if this story is true). Would also fit the FIA's criteria for offering a 12th team charter to an OEM
Ok, thanks.
18 Aug 2025, 22:07
They have 2 factories which is more than Ferrari and Haas have? There are strict regs on what parts can be bought and sold and what parts they have to show their homework? What exactly is the problem? Just the naming ?
650
fwiw .....
Wilbur Gunn the American founder of Lagonda named it using native American name for Buck Creek (Springfield Ohio)
a Lagonda won outright the Le Mans 24 hrs in 1935
a Lagonda raced in pioneer F1 event at 1948 Jersey Road Races (4.5 litre V12 sports car driven by 'that' Robert Cowell)
Lagonda Rapiers ran as 1.5 litre supercharged 2 seater pre and post WW2 ie (not in F1 but F1-legal)
'the Elder Rapier' was rebodied in 1956 as a single-seater and very successful in historic events even post-2000
David Brown bought Lagonda for its 'WO Bentley-designed' 2.6 litre car & engine (whereby AM did big endurance races)
this 'new' Lagonda was the company's saloon car product until discontinued in 1958 (and not replaced)
the car (really more Tresilian-designed) had cills as part of the body not the chassis (a local car known to me for years)
Tommy Cookers wrote:
19 Aug 2025, 16:28
unless I'm wrong and fwiw .....
Lagonda was named after Lagonda Creek (in the USA)
a Lagonda raced in pioneer F1 event at 1948 Jersey Road Races (4.5 litre V12 sports car driven by 'the' Robert Cowell)
my guess is...
The Lagonda is a British luxury car brand established in 1906, which has been owned by Aston Martin since 1947.
The name was revived by Aston Martin in 1974 with the introduction of a full-size luxury four-door saloon, the Aston Martin Lagonda, designed by William Towns.
Macklaren
Macklaren
18 Aug 2025, 22:07
I think that was an issue that Zak had with Horner "cheating" more than anything to do with the rules allowing B-teams
peewon
Matthew Sommerfield from motorsport.com says he's heard Honda isn't doin too badly. He expects them to be competitive
https://www.f1oversteer.com/news/f1-tec ... m-hearing/
One data point and very vague about the sources but first bit of new information regarding the 2026 PU. I would take it with a grain of salt or two though.
peewon
Gary Anderson's in depth analysis of the changes that Aston Martin has made to the front wing which might explain their improved performance at Hungary.
https://www.the-race.com/formula-1/gary ... nce-swing/
-wkst-
-wkst-
And I bet they will do quite well in Zandvoort and will be bad again in Monza. I know its quite boring but they just lack aero efficiency.
STR said it quite clear that no updates really helped but the car only is in the window when it is in a high DF config...
He said the car worked from the Fürst lap in FP1 and the car didnt work elsewhere, no matter what they tried.
-wkst- wrote:
25 Aug 2025, 10:02
Wonder if they run the long sidepods at Monza.
peewon wrote:
25 Aug 2025, 06:41
My issue with Gary's explanation is that he assumes there's less airflow under the nose simply because the gap between the nose and the lowest flap is smaller. He doesn't consider the additional airflow that could result from the lowest flap being positioned higher off the ground—or is it that they just run the nose lower? If the nose is indeed closer to the ground, then the variation in airflow must involve more than just the size of the gap between the nose and the bottom flap.
SSJ4
SSJ4
it's good to be back. that was a long break. mercedes powered cars and fernando normally go well round here.
so hopefully can get close to top 3 on saturday and solid points on sunday again
