yener
Post Fri Apr 26, 2019 11:35 am
1. This is not the topic to talk about it.
2. It is not true
https://twitter.com/AlbertFabrega/statu ... 88/photo/1
Alonso: All the time you have to keep the space!
Post Fri Apr 26, 2019 11:48 am
2. It is not true
Yes, it is true!
gandharva
217
Post Fri Apr 26, 2019 11:50 am
2. It is not true
Your link doesn't show anything. AMUS and other sites are reporting that TR guys only get new ICE and RBR gets a completely new package.
saviour stivala
saviour stivala
-19
Post Fri Apr 26, 2019 12:00 pm
2. It is not true
His link is correct up to before Baku weekend started, FIA PU elements list says (SO FAR). The situation is as I posted. but not yet registered because of the drain cover having stopped the season.
saviour stivala
saviour stivala
-19
Post Fri Apr 26, 2019 12:41 pm
And I left out: the PU elements I listed have been installed and ready to go on both TS cars and both RB cars, as soon as the cars cross the pit-lane exit line their transponders will register the listed elements as having been used.
Gibbs
Gibbs
Post Sat Apr 27, 2019 11:11 pm
Gasly / Honda disqualified for surpassing 100kg/hr flow limit during Q1 hotlap.
https://www.gptoday.net/en/news/f1/2470 ... ng-results
NL_Fer
NL_Fer
63
Post Sun Apr 28, 2019 2:46 am
Intended or by accident?
Gibbs
Gibbs
Post Sun Apr 28, 2019 7:49 am
It's not clear at the moment but I don't take Honda to be the cheating type. The new engine was deployed yesterday so it's possible this was due to a faulty software map.
hollus
Post Sun Apr 28, 2019 8:19 am
Several posts in the last page about dreaming certain results for certian drivers have been deleted as too far off topic.
¡Puxa Esportin!
HondaPOD
HondaPOD
Post Sun Apr 28, 2019 1:01 pm
Minor over consumption : Honda tweaks Gasly's engine after fuel-flow breach
https://www.motorsport.com/f1/news/hond ... u/4377559/
saviour stivala
saviour stivala
-19
Post Mon Apr 29, 2019 7:38 pm
The FIA mandated fuel flow sensor registers what flows through it, it does not restricts or regulate fuel flow, what flows through it is of the team’s making.
Alexf1
Alexf1
16
Post Mon Apr 29, 2019 9:38 pm
Spec2 working fine but no magical hp gap reducer as expected. Hope the originally intended spec2 (now spec3) will still arrive around Montreal. Anyone heard anything about that? Would give them enough old engines for fridays till the end of the season..
Capharol
47
Post Mon Apr 29, 2019 10:22 pm
I guess this Spec 2 wasn't about Quali pace, it was more about getting a better racepace and even more reliabilitty on higher power
Strive for continuous improvement, instead of perfection.
"Most people seem to turn off their brain when they turn on the computer and log in to social media."
shingles
shingles
Post Mon Apr 29, 2019 10:34 pm
Alexf1 wrote:Spec2 working fine but no magical hp gap reducer as expected. Hope the originally intended spec2 (now spec3) will still arrive around Montreal. Anyone heard anything about that? Would give them enough old engines for fridays till the end of the season..
If it wasn’t for the VSC, I am pretty sure Ver would have caught Vet. While you are right there is no magic, I am thinking the results were pretty good - especially on a power track. The fact that a Honda powered car could chase down a Ferrari powered car, THE Ferrari powered car in a race.... pretty hard to imagine last year.
Post Tue Apr 30, 2019 8:23 am
From AMuS (German site)
"Man hört, dass Honda im Verlauf der Saison mit drei weiteren Ausbaustufen plant. Die zweite soll in Montreal oder Paul Ricard kommen, die dritte in Spa und die vierte abhängig von der WM-Situation am Ende des Jahres."
It is said that Honda is planning three more stages/expansion levels during the season. The second should come in Montreal or Paul Ricard, the third in Spa and the fourth depending on the World Cup situation at the end of the year.
https://www.auto-motor-und-sport.de/for ... eit-power/
