63l8qrrfy6
63l8qrrfy6
368
Re: Mercedes Power Unit
I heard it was the block coolant inlet pipe which can be changed without penalty.
zibby43
zibby43
613
Mudflap wrote:
27 Jun 2018, 22:19
That's good news. Thanks for sharing. That would explain why Merc wasn't too worked up about it.
Do you mind sharing the source of that information?
I found this on Albert Fabrega's Twitter (translated by Google Translate):
Perez: The problem in France is under control. It was just a water leak. Engine is OK.
Force India showing what they've got.
roon
roon
412
MtthsMlw wrote:
05 Jul 2018, 14:37
https://pbs.twimg.com/media/DhV0qX5X0AEkOu0.jpg:large
Looks like the gearbox, incl. crash structure, is ~3x longer than the engine.
roon
roon
412
A good look at what I think is the VLM actuator (upper main photo, ignore the arrows pointing to the fuel pump). Long silver housing with hydraulic lines out either end. Has a long flange that would attached to a plenum runner, and lies parallel to the straight section of the plenum, centered between both banks.
anthonyfa18 wrote:
05 Jul 2018, 13:46
honda 2018 fuel pressure pump vs Mercedes 2018
Note the right-hand bank intake plenum is removed, and we see the left hand bank only. Also, the spark plugs and (presumably) pressure sensors are removed on the right hand bank as well.
The actuator shown above also apparent on the 2016 PU:
Re: Mercedes Power Unit Hardware & Software
Updated topic title to better reflect topic's intentions.
ScrewCaptain27
577
Williams-spec PU:
- Serj Tankian
via PG Tech
Big Tea
99
In the top pic above, it looks at first if the wrapping is chaffed through, which I thought was not right. Lookin in magnification it does not seem to be, but looks intentional.
Why would they do this? Is it just a sensor is not attached in the pic or is there a reason to leave a hot spot?
roon
roon
412
I hope they ban engine blankets along with the tire blankets.
63l8qrrfy6
63l8qrrfy6
368
Big Tea wrote:
01 Aug 2018, 14:48
Do you mean on the side of the exhaust manifold (the engine partially covered by a blanket) ?
Big Tea
99
Mudflap wrote:
01 Aug 2018, 21:57
Big Tea wrote:
01 Aug 2018, 14:48
top pic, the outer edge of the pipe, as if it had scuffed the panel, but has a definite 'border' around the area.
Just below the stainless pipe between the flexibles.
63l8qrrfy6
63l8qrrfy6
368
Big Tea wrote:
01 Aug 2018, 22:05
Mudflap wrote:
01 Aug 2018, 21:57
Big Tea wrote:
01 Aug 2018, 14:48
Yeh, the outer edge of the pipe, as if it had scuffed the panel, but has a definite 'border' around the area.
Ah, that's for clearance to car bits.
The manifold is wrapped in an insulating layer held together by a very thin stainless steel sheet. Those clearance dimples are done by locally removing the insulating layer so there's just the sheet steel. They are much more obvious on last year's engine.
