link to article:
http://www.f1technical.net/news/21124
So they want the start to be more driver dependent, but they want the clutch paddle to act like a throttle pedal, did i get that right?
They say it no longer will be able to modulate clutch plate position. Which is very weird.
How do the paddles in semi automatic gearboxes in sports cars work, do they just shift to pre programmed positioning?
This thing about the paddles being responsible for engine rpm just seems weird when the driver has the throttle pedal on the ground to modulate rpm as well.
And it just makes a launch seem much easier. The engineers can simply find out which rpms give a good launch, have steering wheel display engine speed instead so the driver knows how to displace the paddle, and he can manage it from there at the launch with his right foot.
