Reasons for varying performance at high altitude
roon
412
Re: Reasons for varying performance at high altitude
MrPotatoHead wrote:
02 Nov 2017, 02:23
roon wrote:
01 Nov 2017, 22:19
Do the engine test stands adjust their plenum pressure, or drop the pressure in the entire room? To simulate elevation.
Adjusting the plenum pressure would not simulate the different air density.
The only way to do it would be to lower the air pressure being fed to the turbo inlet. But that is troublesome because you have to lower the pressure but still maintain enough volume of air for the engine.
Does seem troublesome. I wonder if OEMs do anything like this. A large enough room and large enough vacuum pumps might suffice to balance what the engine is ingesting.
NL_Fer
82
Wouldn’t a intake restrictor cause the same lower pressure in the intake tube?
roon
412
Wouldn't that be forcing the engine to cause the drop in local pressure?
rscsr
51
NL_Fer wrote:
02 Nov 2017, 22:37
You also have to keep the exhaust at that lower pressure. And a pump to regulate the pressures is just way easier to control than restrictors.
MrPotatoHead
OEM's will test for temperature variations and startup in their test labs but I do not believe they test for air pressure changes.
They typically test that during the road test / test mule phase as far as I know.
But yes as mentioned it's not only the intake side that has a lower pressure but the pressure differential on the exhaust side will be larger relative to atmosphere.
johnny comelately
110
old thread i know, but wouldnt you use a ,say, 5mm bigger compressor wheel
63l8qrrfy6
368
For just the one race?
MrPotatoHead
You would have to sacrifice one of your turbo unit stash to do it.
So yes yo could do it in theory - but it would compromise the rest of the season.
