Dampers bump - rebound
mike
mike
i am playin the game in the Rh2005 mod and i cant understand why my cars alway spin when i hit a chicane while i never have the problem using the 2004 car
how can i fix this problem ?
i have try turn the anti roll bars harder, and i did made it less spining tending
modbaraban
modbaraban
You mean the curbs?
I'd set the rear anti-roll bar softer, softer rear and front fast rebound, harder front anti-roll bar.
Also have a look at your camber settings. Extreme negative camber on the front may cause oversteer and increased tyre wear. Exreme negative camber on the rear may cause bad traction out of corners and brake locking too early... and again increased tyre wear.
mep
29
Sure! In my setups the rear is almost twice as high as the front!
So then tell me how you do it.
I mean I know how, but I want to reach this by mostly lowering the front
to the limit. But this doesn't work so good because there is one point where you didn't get it lower. Especially because another theory is to
have the springs at front harder than at rear.
At rear I have the 2 outer springs as soft as possible.
This is importand for you mike.
I also play 2005rhmod and have had a bit a traction problem out of low
corners like Nürburg first one and France hairpin.
Make rear springs soft and increase at the tyre section the Vorspur
(dont know how to say it in english track or so you will find it if not ask again)
Set it to positive like maybe +0.30 or so, staybles the rear a lot.
mep
29
Maybe we can get some real setup discusions here and
can maybe hit once to test it online.
Fell free to post stup depending things :lol:
modbaraban
modbaraban
I'll post a screenshot of those SUSPENSION related pages later.
PS: and yes, the front is as low as possible (or close to it).
