Aero Help
AeroF1
AeroF1
Aero Help
If I wanted quite a complex model tested for its flow behaviour who out of every one here would be best at CFD to run it for me??
Thanks for your help in advance
KeithYoung
probably russ. what kind of model is it, what did you use to make it, and in what format would you send him the file? probably sending pictures before sending data would be a help. if for some reason this cannot import or the model needs changing is this something you can do, and if not would it be ok for me to tinker around with it? :)
If you dont know russ email etc, go to the technical forum and read the CFD thread.
