2026 Hybrid Powerunits
DenBommer
DenBommer
Re: 2025/2026 Hybrid Powerunit speculation
diffuser wrote:
01 Sep 2025, 16:06
DenBommer wrote:
01 Sep 2025, 09:26
eyelid wrote:
01 Sep 2025, 08:46
Engine rules were simple to follow to this day - now even published official energy diagram is giving false information indicating some teams will brake the engine rules if charging up the battery via ICE. It's not allowed by published rules.
Edit
By Discussing with AI this really looks like that only way to charge battery is via MGU-K by terrible excuses and politics. By a car engineer point of view this looks like driver is trying to brake ICE and MGU-K by putting braking pressure under full throttle on same time on straights. (and even on tight curves according to some A. Newey)
What is going on at Formula 1 really....We may have a good laughs on next season. Even first tests are Top Secret because they know this is going to be a scandal but can't prevent it anymore.
And would this be better if they had a front generator?
Front brake regeneration wasn't a F1/FIA choice. It was blocked by most of the current teams with the thinking it would give Audi too much of an advantage. Mercedes led that charge of blocking front brake regeneration.
And it feels like such a missed opportunity. Look at what Mercedes can do with their AMG GT XX and the three axial-flux motors.
Maybe in the next regulations set, by then Mercedes will have more experience with the GT XX and some other models, and Ferrari too with their WEC cars.
eyelid
eyelid
-6
I am not fully satisfied with these explanations but let's move on to next topic:
Why not electric only drive on pitlane? That would be the actual environmental act to prevent pitlane people to breathe exhaust fumes. What a green washing really.
And yes, we need front axle harvesting also.
mzso
mzso
75
DenBommer wrote:
01 Sep 2025, 11:21
mzso wrote:
01 Sep 2025, 11:02
Tommy Cookers wrote:
01 Sep 2025, 10:50
a front generator and a differential and 2 shafts for driving the generator
any such interconnection of the front wheels has been banned for many years
I think the question implicitly asks: what if it was allowed? (The regs were proposed with front generation at first.)
Indeed, that’s my question, purely hypothetical. What if they had a front generator?
I know a front generator would add some extra weight, but look at how lightweight F1 brakes are compared with a normal street car. I believe they could make a very small, lightweight, compact front generator (using axial-flux technology).
Someone even suggested full-regen braking, thinking it wouldn't require much cooling because it's only used intermittently. It might be interesting as a technological challenge. Also the (probable) massive increase in brake distances should contribute to more overtakes and better on-track action.
670
mzso wrote:
01 Sep 2025, 18:33
that would require about 1500 kW rear braking capacity and about 3000 kW front braking capacity
ie about 12 times the 2026 capacity and about 30 times the present capacity
since the banning of Renault's mass damper it's illegal to have concentrated masses of stuff dotted around the car
apart from unavoidable items such as the wheels - these must be tethered to the car
re so-called 'axial-flux technology' - this only means electrical machines that are disc-shaped not drum-shaped
we already have disc-shaped things called brakes so perhaps we should devise brakes that also generate electricity
DenBommer
DenBommer
01 Sep 2025, 20:38
mzso wrote:
01 Sep 2025, 18:33
ie about twelve times the present capacity
You’ve then got triboelectric technology, but that’s not very efficient.
579
mzso wrote:
01 Sep 2025, 18:33
If you really want to make the racing unsafe, you could simply specify cable-operated drum brakes. Much cheaper.
532
gruntguru wrote:
02 Sep 2025, 01:31
mzso wrote:
01 Sep 2025, 18:33
And more money could be save by only having the brakes on the rear wheels.
As was the norm about 120 years ago.
532
diffuser wrote:
01 Sep 2025, 16:06
I believe that to be a myth.
Front regen would require more weight and a more extensive redesign of the chassis.
And why would it give Audi an advantage? Because they ran a car 10 years ago with a similar setup?
And is running front regen that difficult compared to rear only?
532
DenBommer wrote:
31 Aug 2025, 07:29
wuzak wrote:
31 Aug 2025, 04:41
eyelid wrote:
30 Aug 2025, 20:43
This must the most stupidiest engine rules ever on hybrid era. Only braking energy allowed to charge up the battery - not even ICE can't charge it on it's own to make it thrill and interesting development. This is several steps back to what we have even now.
They can use the ICE to charge the battery.
Up to 250kW under full throttle, less at part throttle.
Yes, I know. They’re now going to burn 20–30 kg of fuel to charge the battery. But then you’re burning expensive synthetic fuel. If you can get that extra kW from braking, it’s kind of “free,” and you can save fuel.
My thought is that front regen will only give substantial gains if it increases to total power recovery.
The example Symonds had was for three 130kW generators - two on the front, one on the rear.
That gives an 11% increase in recovery, but probably slightly more due to slightly longer time at maximum energy recovery during braking.
But it either means all wheel drive or less power for deployment.
Having deployment at lower power compared to recovery means they won't run out of energy as quickly.
Using front regen at the same, or similar power, will still leave the cars at an energy shortfall, requiring fuel to burned to generate electricity.
I am sceptical about the 20-30kg of extra fuel burning. It will probably be about half that - particularly now they will reduce recovery at tracks where braking recovery potential is low - such as Spa and Silverstone.
532
mzso wrote:
01 Sep 2025, 10:45
wuzak wrote:
01 Sep 2025, 09:34
Driver maximum power demand is when the driver is at full throttle.
The rule explicitly states that the MGUK output can be reduced to 0 (must be reduced above 290km/h) and then go into energy recover, up to 250kW. But only when the driver has maximum demand (full throttle).
But it's still possible to recover at partial power demand isn't it? And off throttle?
Yes and yes.
Driver demands X, ICE delivers Y and the MGUK recovers X - Y to give the desired output.
Off throttle = lift and coasting, which will happen.
532
karana wrote:
01 Sep 2025, 15:32
The rule itself doesn't slow the cars, it actually prevents them from harvesting at 350kW and hence from slowing the cars too much. Harvesting at full and partial throttle is anyway something that can be done already with the current PUs.
With an assumed ICE power of 400kW, harvesting at 250kW will still mean a net power of 150KW. What's supposed to be dangerous about it?
Power is proportional to drag and the cube of power.
If a car can go 300km/h using 400kW, and then power is cut to 150kW, speed will reduce to ~216km/h.
The worry was that the drop would be sudden when the battery ran out of energy, but that is mitigated by the ramp rates now.
wuzak wrote:
02 Sep 2025, 04:56
diffuser wrote:
01 Sep 2025, 16:06
Yeah, I read that Merc said that too...in 2022. I guess I could have lead with that. In any case, it wasn't the FIA/F1 that didn't want it.
You'd probably go with 4 wheel drive, if you're gonna have front wheel regeneration. No point in having a a motor to regenerate but not feed it power to power the car.
They could have made the rear motor smaller to compensate.
DenBommer
DenBommer
diffuser wrote:
02 Sep 2025, 06:39
wuzak wrote:
02 Sep 2025, 04:56
diffuser wrote:
01 Sep 2025, 16:06
They could then use the front motor as a push-to-pass system, or just for exiting corners and then disconnect it for more efficiency (like the principle of the Mercedes AMG GT XX).
Or, like in WEC, the front motor could be activated only within a speed limit (for example, 150 km/h).
579
wuzak wrote:
02 Sep 2025, 05:17
Typo. I know you meant velocity.
532
gruntguru wrote:
02 Sep 2025, 09:00
wuzak wrote:
02 Sep 2025, 05:17
Yes, thanks for that correction.
