2026 Hybrid Powerunits
532
Re: 2025/2026 Hybrid Powerunit speculation
FW17 wrote:
06 Nov 2025, 10:01
I dont think rules allow harvesting at full throttle.
The car at full throttle with with 450kw ICE power to the wheels travelling with the wings open at over 340kph, suddenly drops to 200kw to the wheels (because as per some posts above) and 250kw to the generator will cause a sudden drop in speed. This is enough for the car behind to slam straight into the back of the car.
The engineers would have made some stupid map that would have shown in sim to generate, top up and deploy at the exit to be faster than defending on the straight, similar to the DRS games Max and Charles were playing in the beginning of 2022 season.
Regen at max throttle is not going to be allowed.
"Suddenly"?
The power may not be reduced at a rate greater than 100kW/s for most tracks, and 50kW/s for tracks with a large amount of full throttle running.
For the former it will be reduced from 0kW to -250kW in 2.5s, the latter 5s.
This will happen at the end of straights,leading into the braking zone.
Also, can you explain why the rules allow for a maximum reduction of 600kW when the driver is at full throttle, and that the MGUK must remain above -250kW when at full throttle?
These are explicitly stated in the regulations, as shown many times.
532
FW17 wrote:
06 Nov 2025, 15:01
Badger wrote:
06 Nov 2025, 11:01
FW17 wrote:
06 Nov 2025, 10:01
Read the quoted rules at the top of the page maybe.
https://i.imgur.com/wMG6lTY.png
Tell me how a driver demands 218 kw halfway down the straight?
That is from the part throttle fuel flow regulations, which the driver will not use on the straight, at least not in normal conditions.
Badger
Badger
46
FW17 wrote:
06 Nov 2025, 15:01
Badger wrote:
06 Nov 2025, 11:01
FW17 wrote:
06 Nov 2025, 10:01
Programmable software regulates the maximum power demand, same way it does now with deployment.
Actually I think the guy who posted before used an older set of the 2026 regulations. The most recent edition I can find stipulates the following:
5.14.8 The driver maximum power demand must not be reduced at any greater than the rates defined
below:
a) 50kW in any 1s period at Competitions where the FIA determines that the power
limited distance exceeds 3500m. These Competitions and the vehicle fundamentals
used for the calculation of the power limited distance may be found in the Appendix
to the Technical and Sporting Regulations.
b) 100kW in any 1s period at all other Competitions.
Furthermore, the total power reduction is limited to a maximum of 450kW and the resulting
electrical DC power of the ERS‐K must remain above ‐100kW.
In other words, full throttle harvesting will be available but limited to -100kW.
The way they get around your worries about suddenly slowing is obviously by mandating that you gradually reduce deployment, which is covered in the same regulation above.
BassVirolla
Badger wrote:
06 Nov 2025, 15:34
FW17 wrote:
06 Nov 2025, 15:01
Badger wrote:
06 Nov 2025, 11:01
below:
Well, reduced from 250 to 100kW, but still allowed.
It's been a while since I stopped posting and reading the technical regulations, because there are some posters not willing to believe not me but the governing body.
532
Badger wrote:
06 Nov 2025, 15:34
below:
I was quoting issue 13 from July, but it is the same for issue 14 from mid October.
C5.12.6 Unless the electrical DC power of the ERS-K is negative, the driver maximum power demand must not be reduced at any greater than the rates defined below:
a. 50kW in any 1s period at Competitions where the FIA determines that the power limited distance exceeds 3500m. These Competitions and the vehicle fundamentals used for the calculation of the power limited distance may be found in the document FIA-F1-DOC-Cxxx.
b. 100kW in any 1s period at all other Competitions.
Furthermore, the total power reduction is limited to a maximum of 600kW and the resulting electrical DC power of the ERS-K must remain above −250kW.
The part highlighted in red is new in Issue 14.
Issue 11 from February said:
C5.12.8 The driver maximum power demand must not be reduced at any greater than the rates defined below:
Furthermore, the total power reduction is limited to a maximum of 450kW and the resulting electrical DC power of the ERS-K must remain above −100kW.
Issue 12 from June said:
C5.12.6 The driver maximum power demand must not be reduced at any greater than the rates defined below:
Furthermore, the total power reduction is limited to a maximum of 450kW and the resulting electrical DC power of the ERS-K must remain above −100kW. These limits are changed respectively to 600kW and -250kW for the Sprint Qualifying and Qualifying sessions.
532
Badger wrote:
06 Nov 2025, 15:34
The latest regulations can be downloaded from https://www.fia.com/regulation/category/110
Badger
Badger
46
wuzak wrote:
06 Nov 2025, 16:23
Badger wrote:
06 Nov 2025, 15:34
Okay, I was referring to michl420's post. But reading your post it actually seems that my interpretation is the outdated one. Because it says -250kW in the later issues. So you will be able to do quite a lot of full throttle harvesting then.
mzso
mzso
75
FW17 wrote:
06 Nov 2025, 10:01
If the regs allow it it will be, until it's changed... They set limits on how fast output power can be decreased.
wuzak wrote:
06 Nov 2025, 11:44
Why would the rpms increase when the driver lifts off/brushes the brakes and the MGUK is recovering energy?
What is the source of this "new for 2026 rules allowing energy recovery when cornering"?
How would that even be possible? The car would just speed up...
mzso
mzso
75
Tommy Cookers wrote:
04 Nov 2025, 02:15
for 2026 there seems to be no consumption limit ?? - only a fuel (heat) rate limit
again to help the least competitive teams give a better impression eg by having sufficient electrical energy
There is an energy limit, isn't there? Which based on the fuel blend will be calculated in to fuel mass.
532
mzso wrote:
07 Nov 2025, 01:46
04 Nov 2025, 02:15
Not that I have seen so far.
mzso
mzso
75
wuzak wrote:
07 Nov 2025, 01:49
mzso wrote:
07 Nov 2025, 01:46
04 Nov 2025, 02:15
I guess I badly misremember then. So that's even more incentive to regen while turning, all the time.
Which I expect is a motivation towards ultra high rpm MGUs, so they can be reasonably efficient with low ICE rpm as well. (I do remember right that there can be a gear ratio between the ICE and the MGU, right?)
saviour stivala
saviour stivala
43
The '-100 kw limit': This negative power figure (- 100 kw) signifies that the MGU-K can't put more than 100 kw of resistance on the powertrain while its harvesting. This is done to prevent the car from dramatically slowing dawn on straights, an issue known as''clipping''.
579
FW17 wrote:
06 Nov 2025, 15:01
Badger wrote:
06 Nov 2025, 11:01
FW17 wrote:
06 Nov 2025, 10:01
He would need to lift his right foot to a "part-throttle" position.
Now - tell me why you want to know. The table I created shows how part-throttle harvesting is regulated by the FIA. I doubt that it will be applicable halfway down the straight.
532
mzso wrote:
07 Nov 2025, 01:57
wuzak wrote:
07 Nov 2025, 01:49
mzso wrote:
07 Nov 2025, 01:46
Maximum MGUK speed is limited.
C5.18.5 The relative rotational speed between any two parts of the MGU-K may not exceed 60,000rpm.
579
mzso wrote:
07 Nov 2025, 01:37
wuzak wrote:
06 Nov 2025, 11:44
True. The driver will need to select a gear that creates appropriate rpm through the corner to meet his harvesting requirements. e.g. if maximum harvesting is required, they will have to corner in a gear that sets the rpm above 10,500.
