mzso wrote: ↑14 Dec 2025, 19:41
diffuser wrote: ↑14 Dec 2025, 08:17
mzso wrote: ↑11 Dec 2025, 19:48
Not as inefficient as you seem to expect. And in some circumstances it could be more efficient, when you use the best time to charge and deploy. Due to the ICE having a narrow efficiency range, near the peak, and the MG having a broader one, as well as being a lot more efficient overall.
Don't forget, this is not fuel that was pulled out of the ground. It's sustainable fuel...To a certain degree, they don't care how much of it they need to burn.
It doesn't matter what they actually burn. The efficiency of the technology is what matters.
diffuser wrote: ↑14 Dec 2025, 08:28
hsg wrote: ↑13 Dec 2025, 00:28
Is that is case, late brake drivers will loose their performances?
Not sure you understand, in 2026 you will have less downforce, normal braking will just take more meters because if you brake harder, you'll just lock up the wheels. The late brakers have the ability to stop later that others and still not lock up the tires. That will not change. Just late braking in 2026 will not be as late as it was in
2025. You still need the "touch" to perform the late braking and if you have it, you'll still be able to make use of it.
In the context, it seemed to me that he meant that late brakers will have less power available, due to reduced regen.
What does less power have to do with braking late?
With regards to efficiency...I meant the FIA don't care how much fuel you burn over a race(fuel efficiency). There is no fuel tank size limit, just a flow limit. The fuel itself isn't considered creating CO2 emissions. I'm not talking about from a racing perspective. Obviously, from a racing perspective, the more fuel you have to carry, the slower you'll be. The fuel flow limit is measured in energy. We did the calculations a couple of weeks ago in these pages. Full throttle for 1.5 hours, you can easily burn through 150 liters. The ICE will work harder next year off full throttle to make up for a lack of MGU-H. Let's say the PU power comes 50% from the MGU-K and 50% ICE. Anything 50% and less will come the ICE only. If the demand for power is 30%, the ICE will be working at Max power with 30% going to drive and the other 20% to spin the MGU-K to charge the battery. All this to say, next year it's gonna be interesting to see on a track that normally was 65% full throttle, how much more of the time the ICE will be at 100%!. A track like Monza that was like 75% full throttle in
2025 will the ICE be at 100% for 95% of the race?
