2026 Hybrid Powerunits
venkyhere
43
Re: 2025/2026 Hybrid Powerunit speculation
Motorsport.com discusses the formation lap problem, but doesn't offer much insight :
https://www.motorsport.com/f1/news/Why- ... /10803679/
But why did so many cars arrive on the grid without energy? This is linked both to the limited amount of energy available and to the way drivers warm up their tyres and brakes.
“It's our responsibility to avoid to be in that situation. We have been caught by some limitations of the way you can charge and discharge the battery in the formation lap,” added Laurent Mekies on the topic,...
"With the unusual behaviours that drivers need to have on a formation lap – with acceleration, braking, acceleration, braking to warm your brakes, to warm your tires – we ended up in a point where we were unable anymore to get to the right state of charge for the race start. We had to build up that battery level through the first lap, which obviously was not enjoyable,” added the Red Bull team principal.
To try to warm the tyres and brakes, drivers generally adopt quite an aggressive driving style during the formation lap, alternating constant cycles of acceleration and braking. The battery therefore comes under heavy stress, because the car repeatedly transitions from low to high speeds and energy consumption increases significantly during the acceleration phases.
On a track like Melbourne, which offers few real opportunities for recharging, this continuous cycle does not help, also because the last real chance to recover energy is the braking zone at Turn 11 following two long straights. By proceeding more slowly in the final sector, it becomes much more difficult to recharge the battery because the recovery action of the MGU-K is reduced.
A second problem is added to this. To warm tyres and brakes, the brake balance is often shifted toward the front axle, altering the relationship with the ERS: it is the same principle as what Mercedes, until last year, called “brake magic”, which aimed to generate temperature before lining up on the grid or during Safety Car periods when cars proceed more slowly.
With the braking action shifted more toward the front to generate temperature, the motor-generator is required to work less. Under “normal” conditions this year, the rear braking system has actually been reduced in size because the MGU-K provides much of the deceleration. On a challenging circuit like Melbourne, however, finding the ideal procedure was not simple, and several engineers were caught by surprise, arriving on the grid with empty batteries.
There is one piece of info that answers one of the Qs in my original post :
Compared to a normal qualifying out-lap – where the FIA grants an exception allowing up to 8.5 MJ of energy to be recovered and where cars tend to leave the pits with the battery already fairly charged – the formation lap follows different dynamics.
which kind of reinforces my guess that they are not 'enabling a switch'/changing mode from a typical race lap, for the formation lap - it's not treated 'special' like the outlap before a quali lap.
Farnborough
Farnborough
152
There's, effectively, zilch boost and consequential torque available to carry out traditional style rear tyre heating as previously done on formation lap.
Same as start, needs extreme revs to build anything like the torque curve needed to complete this. Otherwise its a 1600cc atmo pu against massive rear tyre traction.
It would probably risk both the clutch and 1st gear ratio integrity if attempted too.
mzso
mzso
76
venkyhere wrote:
11 Mar 2026, 09:26
As astonishing as it sounds it looks like no-one bothered to simulate and/or to coach the drivers how to do a warm-up lap that both warms up the tires and retains enough charge.
I don't understand part about an exception. The 8.5 MJ is just as allowed to be recovered here as every, as far as I know. So what's the exception about? And I don't think they are not allowed to top up the battery, and even if that was the case they'd make sure to recharge it during the qualifying in-lap.
So maybe it's a special recharge engine mode, vs race mode. But that doesn't excuse them not running the ICE agains't the K on the grid which would have also helped with the spooling. More exhaust, more turbo RPM.
The Antonelli part is also weird, why did only had a problem doing a burnout? De he waste the charge on the inspection lap already? But also I would think 400 is kW is enough to spin the wheels. The could have revved the engine beforehand without limitation. And in any way. There is no K power before 50km/h. (BTW he's just out of frame on the broadcast footage)
Farnborough wrote:
11 Mar 2026, 09:43
But they have unlimited time to rev up. The warm-up lap starts at exactly the hour by the local clock. I guess Russel and most of the rest was wiser.
Farnborough
Farnborough
152
mzso wrote:
11 Mar 2026, 14:06
venkyhere wrote:
11 Mar 2026, 09:26
Farnborough wrote:
11 Mar 2026, 09:43
The turbo doesn't stay on boost after one application, it only spools up effectively under full load .... then drops if the throttle is closed. 10/15 secs of high rev for EACH burnout iteration is not going to happen.
Have you ever driven anything with turbo lag ?
Also, 400kw is never going to be available without the turbo at peak.
mzso
mzso
76
Farnborough wrote:
11 Mar 2026, 14:11
Well, I'm assuming burnout is manly relevant for leaving the grid from standstill, otherwise it's weaving and heavy braking.
FW17
184
Farnborough wrote:
11 Mar 2026, 14:11
Is hot blowing banned or not enough to keep the turbo spooled?
Farnborough
Farnborough
152
mzso wrote:
11 Mar 2026, 14:15
Farnborough wrote:
11 Mar 2026, 14:11
Up to last season they were all doing three iteration of burnout in final phase, on the straight to the grid positions. They also check clutch function and response, I believe during these events.
Guess that status quo can't be facilitated under these rules.
Farnborough
Farnborough
152
FW17 wrote:
11 Mar 2026, 14:21
Farnborough wrote:
11 Mar 2026, 14:11
I'm unsure of exact ruling around this .... that's illustrative of just where this rules set has got to though :wtf: but "blowing" would describe off throttle airflow while spinning the crankshaft with kinetic from the wheels, that while any throttle restriction was removed (open) and no fuel delivery as a mode. That's as I understand it.
Nothing builds turbo boost like combustion under load though, and why many turbo installation always have to deal with lag in reality.
It just doesn't appear well thought through, does it.
It was MGU-H of course that facilitated this previously. That by spooling the turbine shaft from battery power to give enhanced boost while ICE was ineffective for that purpose, and why they could fully launch, initially, at low rpm.
FW17
184
Farnborough wrote:
11 Mar 2026, 14:39
FW17 wrote:
11 Mar 2026, 14:21
Farnborough wrote:
11 Mar 2026, 14:11
Hot blowing was fuel burning during the exhaust stroke
Farnborough
Farnborough
152
My understanding is currently any fuel into exhaust system is forbidden.
They of course are carrying less in this era too.
FW17
184
Farnborough wrote:
11 Mar 2026, 15:41
Fuel is only in the cylinder, the spark is delayed till the exhaust port is opened
Farnborough
Farnborough
152
FW17 wrote:
11 Mar 2026, 16:30
Farnborough wrote:
11 Mar 2026, 15:41
Yes I understand how that works, but thought the control was in ignition etc to specifically prevent this eventuality. The rules don't want it, in other words.
Thats my understanding from reading posts on here containing the FIA section relevant to this aspect.
They'd certainly be doing that IF allowed, as none of the PU manufacturers would be lacking this knowledge.
MJL
MJL
Hi, I am reading the PU rules now and this part makes me think:
C5.12.6 [..]
Furthermore, the total power reduction is limited to a maximum of 450kW and the resulting electrical DC power of the ERS-K must remain above −100kW. These limits are changed respectively to 600kW and -250kW for the Sprint Qualifying and Qualifying sessions.
Does it mean superclipping in the race is capped to 100kW? I'm looking at Issue 12 from 10/06/2025, are these the latest rules?
532
MJL wrote:
12 Mar 2026, 01:59
C5.12.6 [..]
Issue 16 was published at the end of February.
C5.12.6 was changed in Issue 13:
C5.12.6 The driver maximum power demand must not be reduced at any greater than the rates defined below:
a. 50kW in any 1s period at Competitions where the FIA determines that the power limited distance exceeds 3500m. These Competitions and the vehicle fundamentals used for the calculation of the power limited distance may be found in the document FIA-F1-DOC-Cxxx.
b. 100kW in any 1s period at all other Competitions.
Furthermore, the total power reduction is limited to a maximum of 600kW and the resulting electrical DC power of the ERS-K must remain above −250kW.
FittingMechanics wrote:
10 Mar 2026, 22:40
Are they not able to put the engine in "no electrical use at all" mode? So they do the formation lap purely on ICE power, surely 400 kW can spin the rears at low speeds?
I believe this is relevant:
BorisTheBlade wrote:
12 Mar 2026, 13:14
It means, that teams are basically allowed to use only the ICE starting full-throttle during these sections. In all other sections they are forced to start with at least 200 KW MGU-K on full-throttle.
MGU-K deployment is forced at full throttle, and then there's a specific ramp down rate (iirc its 50kW/s).
Getting the battery level right is very complex because the tire and brake warmup procedures are done in a way that cannot be predicted and must be done until the target temps are reached.
#ReleasetheADUO
