Badger wrote: ↑27 Apr 2026, 15:16
F1 trying to become 50% Formula E was a big mistake, hence all the complaints we see in 2026.
There is still no severe issue in principle with the 50/50 split power units. Formula E supposedly getting 50% of its total power from the regenrative braking proves as much. Sure, FE uses a ton of lift and coast, but F1 could compensate for that with an MGU-K.
750kW brake harvesting with front axle regen and an MGU-H would make the 50/50 split conpletely fine when combined with active aero. There would be boatloads of battery power available.
Only politics is the issue. Well, that and weight. It would be heavy as hell, but could proooobably stay below
2025 weight, at least if they made compromises like 13 inch rims.
