Ever the optimist. Rear limitation is much more preferable to front.
I’m not disputing your post, just having a rantVettel165 wrote: ↑06 Apr 2025, 18:50Lando confirmed my post. Did Red Bull found something in the low-speed, as this was our main weakness last year.
" High-speed we were very, very strong and I think definitely the strongest car out there. Slow speed—we’re quite a chunk off the Red Bull, and that's where we lost yesterday in qualifying"
If by 'slow speed' Norris is referring to turn11 hairpin and the final chicane, I think he is blaming the car instead of his own driving style. Piastri didn't have problems with both these places. Norris wasn't attacking the chicane like Piastri and Verstappen were, and unlike both of them who were taking an 'wider, outer' line with higher min-speed through the hairpin, Norris was always taking the tighter, slower, shorter line (which I reckon delayed his throttle application at exit) - this is my 'read' from the helicam video shots.Vettel165 wrote: ↑06 Apr 2025, 18:50Lando confirmed my post. Did Red Bull found something in the low-speed, as this was our main weakness last year.
In the low speed chicane exit Max could stab the throttle more out of the corners in Q3. That was evident.Vettel165 wrote: ↑06 Apr 2025, 18:50Lando confirmed my post. Did Red Bull found something in the low-speed, as this was our main weakness last year.
Because front deg is mostly a function of how the car works the tyres, suddenly the grip starts going and the understeer gets worse and worse. No amount of skill in the world can make an understeery car go fast around a corner, the only way to mitigate it is to go slow (see Max's first stint in China). With rear deg it's a function of how the car AND the driver work the tyres. If the driver controls sliding and traction well it helps a lot, and Max is very good at that. It's advantage McLaren because their car is faster and kinder on the tyres, but it's a track where a driver can make a difference.Sergej wrote: ↑06 Apr 2025, 18:57yeah always safer to keep expectations at bayanyway, why do you think rear limitation is much more preferable to front ? it's a general thing or are you saying that with respect to RB21 ?
The last chicane is all about the kerbs. RB used to be terrible on the kerbs so it's surprising to see them do well in that sequence. Still, Oscar was purple in S3, so it was mostly due to Lando bottling it.ringo wrote: ↑06 Apr 2025, 19:38In the low speed chicane exit Max could stab the throttle more out of the corners in Q3. That was evident.Vettel165 wrote: ↑06 Apr 2025, 18:50Lando confirmed my post. Did Red Bull found something in the low-speed, as this was our main weakness last year.
Norris is correct here. May well be down to the different PUs and not necessarily the chassis.
Watch the videos again or telemetry on the steepness of the throttle application exiting the chicane.
Great analysis. This forum is really fantastic.Cs98 wrote: ↑06 Apr 2025, 20:35Because front deg is mostly a function of how the car works the tyres, suddenly the grip starts going and the understeer gets worse and worse. No amount of skill in the world can make an understeery car go fast around a corner, the only way to mitigate it is to go slow (see Max's first stint in China). With rear deg it's a function of how the car AND the driver work the tyres. If the driver controls sliding and traction well it helps a lot, and Max is very good at that. It's advantage McLaren because their car is faster and kinder on the tyres, but it's a track where a driver can make a difference.
Appreciate your analysis, even though I'm not sure I agree that a driver can make much more difference in a rear limited track where anyway you have to rely on a good traction/rear from you car (and McLaren is best here), while for example just this weekend we had a very good demonstration of how much a difference a driver can make on a front limited circuit like Suzuka. Hopefully I'll be proved wrongCs98 wrote: ↑06 Apr 2025, 20:35Because front deg is mostly a function of how the car works the tyres, suddenly the grip starts going and the understeer gets worse and worse. No amount of skill in the world can make an understeery car go fast around a corner, the only way to mitigate it is to go slow (see Max's first stint in China). With rear deg it's a function of how the car AND the driver work the tyres. If the driver controls sliding and traction well it helps a lot, and Max is very good at that. It's advantage McLaren because their car is faster and kinder on the tyres, but it's a track where a driver can make a difference.
I wouldn't call Suzuka front limited. It's nothing like China.Sergej wrote: ↑06 Apr 2025, 21:05Appreciate your analysis, even though I'm not sure I agree that a driver can make much more difference in a rear limited track where anyway you have to rely on a good traction/rear from you car (and McLaren is best here), while for example just this weekend we had a very good demonstration of how much a difference a driver can make on a front limited circuit like Suzuka. Hopefully I'll be proved wrongCs98 wrote: ↑06 Apr 2025, 20:35Because front deg is mostly a function of how the car works the tyres, suddenly the grip starts going and the understeer gets worse and worse. No amount of skill in the world can make an understeery car go fast around a corner, the only way to mitigate it is to go slow (see Max's first stint in China). With rear deg it's a function of how the car AND the driver work the tyres. If the driver controls sliding and traction well it helps a lot, and Max is very good at that. It's advantage McLaren because their car is faster and kinder on the tyres, but it's a track where a driver can make a difference.![]()
No that's just Lando deflecting. He gave up 1 tenth to max on the final lap by braking too early for the chicane. Oscar on a previous lap did the chicane at the same speed as max did on his pole lap, so it was in the car.Vettel165 wrote: ↑06 Apr 2025, 18:50Lando confirmed my post. Did Red Bull found something in the low-speed, as this was our main weakness last year.
