Dee
Dee
Max now using the same wing as Yuki
TNTHead
I watched some onboards, most of the time the car seemed reasonably planted. But one push lap in his cool down/fast lap sequence he was over correcting a lot. I think tire temps where then out of the window. I suspect they were only on high fuel to optimize the balance on high fuel. As VER said after FP2: I prefer race pace over one lap pace, so thats what they are aiming for. Expecting NOR on pole. VER 2nd would be not too bad with the run down to T1.
49C track temp. :?
Beware of T-Rex
Sergej
25 Oct 2025, 22:58
49C track temp. :?
perfect for McLaren
so Max reverted back to mid DF wing ?
pantherxxx
pantherxxx
Piastri is slow. At least beat him.
Vettel165
Why did they changed that rear wing right before qualy. Of course you will struggle more, a shame Red Bull is sometimes making that changes... Well it is now what it is.
Dee
Dee
In Austin, there was 7 tenths between Max and Yuki in Q1, 3 tenths between them atm.
Sergej
car is super nervous in the fast turns of S2
Valeo
Valeo
Too much fiddling around with the setup, doesn't look good anymore from the onboard
Dee
Dee
Valeo wrote:
25 Oct 2025, 23:17
Changing the wing might not help as well..
Valeo
Valeo
Imagine that's only row three or something, race pace won't matter ☠️
looks like a mess and Mercedes and Ferrari are there. :lol:
Beware of T-Rex
euv2
euv2
16
Sector 1 is good now, sector 3 is also competitive, need to figure out the fast corners, if Max can do that, should be very competitive for pole. LEC, MAX and NOR only drivers to use 1 set.
f1isgood
f1isgood
It's so over 🤣
Thanks for the hopium while it lasted I suppose.
Dee
Dee
Someone said Max was on used softs for that last lap..
