JohnsonsEvilTwin wrote:feynman wrote:They had at least 3 seperate wind tunnels spinning across the planet, and most of the juicy-goodness that made the BGP-01 special came from aero-engineers working outside of the Brackley setup.
The wind tunnel at Brackley was completed in July 2006. Its calibration took a very long time as you can probably tell from the earth car disasters.. :lol:
But 3 windtunnels?
Superaguri didnt really add anything to the BGP 001 and the half scale aero tunnel Honda used before was used sparsley by Zander who was based at Brackley and largely regarded as the father of the double
diffuser.
Cleverer people than I will know but Aero calibration erros can be sorted fairly quickly with the right software no?
Calibration and upgrade of aero tunnels can take from 6 weeks to a year, sependant on spec. Williams upgraded and re calibrated its tunnel this year on Rubens demand, that one was a quick one that took arround 10 weeks, just about where the Williams drop off post Barcelona came in and finished at Silverstone. In 2007 it took a year for renault to upgrade its tunnel, and the whole thing wasnot calibrated properly and was all down to a leading edge of a pannel creating disturbance in the air flow (as the pannel was all of 1mm too proud) making the figures wrong. Renault took the first 12 weeks of 2008 to calibrate the tunnel. And look at what came out of the tunnel towards the end of 2008, the 3rd best car that year at that point as BMW Sauber had halted the F1.08 for the F1.09 development.
If i were Mercedes, id take a short period of upgrade and re-calibration at the start of 2011, ideally when the cars are shipped off to Bahrain for Testing, about a week later the tunnel should be shut down for about 6 weeks, tested, upgraded and calibrated. It would mean that come Barcelona, they could have updated only tested using CFD, but come Istanbul they will have a full upgrade package.
I can see where Nick Wirth is coming from with CFD, but i think if you are running with a weighty CFD package, you should have arround 30% of the aero testing done in a tunnel just for figure proveing.
There is one other example in F1 where the CFD facility actually had to be re-calibrated to date, and that was belived to be at Toyota as the 2007 car was a dog and out came in 2008 a car that with a little luck could have won a race or two with the right driver.
Maybes mercedes should check the calibration on both Tunnel and CFD facilities.
