2026 Aston Martin Aramco Formula One Team
671
Re: 2026 Aston Martin Aramco Formula One Team
BassVirolla wrote:
08 Apr 2026, 10:14
Tommy Cookers wrote:
08 Apr 2026, 10:11
BassVirolla wrote:
08 Apr 2026, 09:58
A permanent magnets machine spinning at high speeds under non electrical load produces very high voltages, and that can put multiple elements under risk.
Put it in other way, with permanent magnets you have to recover or deploy, but not spinning at zero current.
fwiw I totally disagree
I'll be more than happy to be factually corrected (as with some explanation / link / whatelse). I assume I can be wrong, but I don't like to be left in the dark.
a wound field machine could develop excessive open circuit voltage if the field becomes too weak (ie excess voltage constant)
eg if the field energisation fails there is likely a weak residual field
ok a permanent field can become temporarily or permanently weakened by excess current/magnetism or temperature
this is relatively unlikely ie a fixed field (permanent magnet) is much safer (than a wound field) in this regard
road 'electric' cars often have a combination (hybrid) field to economise on PM material
Jambier
Nikosar wrote:
08 Apr 2026, 10:41
even with a Mercedes engine the car would likely only be around the level of Alpine or Haas.
So basically fighting for best of the rest, back to 2024.
Which is not so bad, considering a very overweight car with several months of dev missing compare to those teams
CHT
CHT
-7
From the screen grab you can see how deep the MGU-K it place inside the survival cell in front of the ICE and how close the battery is attached to the ICE. I believe the base of the MGU-K is also mounted to the survival cell, which may also contribute to vibration. And where are the electric cable linking the MGU-K to the battery? Perhaps MGU-K and Battery are integrated?
ImageHonda PU 2, on Flickr
@ 0.30
Looking at how the MGU-K electronic box is stack above the battery cell, it may also be difficult to move the battery further from the ICE due to the height touching back of driver seat.
The battery doesn't have to be moved at all. I interpret the reports from Honda to mean that they added additional bracing to Astons chassis where the batter and MGUK is but had to remove it because it is not their place to be adding stuff to the customer's chassis.
This bracing would have shifted the natural frequency of things a bit higher so that they can pinpoint the source a bit better. And then try apply vibration prevention in a more targeted way.. Whether it is by engine dampers, combustion tuning, counterweights, new timing gears, redesign of MGUK stator etc whatever it is that's reaquired.
CHT
CHT
-7
PlatinumZealot wrote:
09 Apr 2026, 04:12
Taken from some earlier article, it mentioned the battery vibration issue is due to what is was mounted to.
From the earlier post, we can see that both MGU-K and battery are mechanically mounted to the survival cell,
When the MGU-K is the vibrating, it will transmit the vibration to the cell and to the battery and the driver,
To solve the vibration issue on the battery would have been easy by damping mounting, but I suspect the problem could be much more and the battery and MGU-K could be mechanically attached to each other to avoid the need of running cables.
And why is the MGU-K vibrating so much that is affecting the driver? that is the main problem Honda is trying to solve. And its very likely that they will end up detaching the MGU-K from the survival cell. which mean new engine and new battery pack.
The problem identified in testing was that the battery pack was being aggressively shaken because of the severe vibrations running through what it was mounted to. This was then causing damage to the battery system.
https://www.the-race.com/formula-1/ever ... -briefing/
671
CHT wrote:
09 Apr 2026, 01:31
... And where are the electric cable linking the MGU-K to the battery? .....
there is no such cable
the MGU-K is energised and energises by the so-called CE not by the battery
CHT
CHT
-7
09 Apr 2026, 10:18
CHT wrote:
09 Apr 2026, 01:31
You can see the cable connecting the MGU-K to battery
Tommy is right from an electrical circuit point of view. From a visual point of view though it may only appear like the whole thing is connected to the battery so I see why some people think so. Practically we know what each other mean.
CHT wrote:
09 Apr 2026, 12:02
09 Apr 2026, 10:18
CHT wrote:
09 Apr 2026, 01:31
https://global.honda/en/tech/motorsport ... es/04.webp
He means the CE is in the middle,it is connected to both the battery and the MGU-K. In your picture of the old Honda PU, CE isn't obvious there. The old Honda PU had a separate box for the CE, maybe we're just losing it in the gray. That's the box they now stack on the batteries in the 2026 PU. Maybe it's just not in the picture cause it's a standard Part across all teams?
671
diffuser wrote:
09 Apr 2026, 18:32
'... He means the CE ....
Maybe it's just not in the picture cause it's a standard Part across all teams? ...
afaik
it wouldn't be a standard part unless the MG is a standard part
the so-called CE is functionally a part of the MG like the cylinder head is functionally a part of the ICE
each revolution of the MG is timed and logged for monitoring & control purposes
the CE makes the MG go like the cams, valves, injection, ignition etc make the ICE go
the battery is just a fuel tank
09 Apr 2026, 20:16
diffuser wrote:
09 Apr 2026, 18:32
afaik
Thought it was a standard part like a PC that runs an OS. The maps and shiit are apps that run on it are different. Isn't it made by McLaren?
collindsilva
collindsilva
Not sure it is related to this tread, but saw some video on reddit of Aston Martin testing some Frankenstein car a clone of Valkyrie and F1, not sure the purpose behind it
GoranF1
GoranF1
149
collindsilva wrote:
10 Apr 2026, 07:11
Testing PU?
collindsilva
collindsilva
GoranF1 wrote:
10 Apr 2026, 08:41
collindsilva wrote:
10 Apr 2026, 07:11
Testing PU?
Is it allowed ..
Waz
Waz
GoranF1 wrote:
10 Apr 2026, 08:41
collindsilva wrote:
10 Apr 2026, 07:11
Testing PU?
Wouldn't it have been less conspicuous to fit the PU into a standard Valkyrie? Or at least the WEC Hypercar?
If that video is even real, it's raising a lot of questions on different platforms. If we know about it, the other teams also do.
