2026 Aston Martin Aramco Formula One Team
TyreSlip
TyreSlip
Re: 2026 Aston Martin Aramco Formula One Team
diffuser wrote:
16 Apr 2026, 15:06
TyreSlip wrote:
16 Apr 2026, 14:33
The performance improvement would come from running the engine at full revs, which could not be done safely previously.
Just imagine what 13.5K over 11.5K RPM in 8th gear can mean for top speed down the back straight in Miami!
Well, it will be better than the current 11.5K RPM. But team members have already stated the engine was not too far from running at full capacity anyway, so I expect any improvement to be minor until a real engine upgrade.
FNTC
FNTC
"Obviously not where we want to be, but with the potential to be up front at some point in the season."
Bence
Bence
If the engine has operated let's say at 75% of its potential, can someone calculate the theoretical 100% performance?
TyreSlip
TyreSlip
FNTC wrote:
16 Apr 2026, 18:19
With the word "potential," it is a meaningless quote. Almost Ronspeak-esque.
WardenOfTheNorth
Bence wrote:
16 Apr 2026, 18:36
I don't think it's that easy, especially with these PU as it's not a linear progression.
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
etusch
131
Considering that the maximum speed gap is generally around 20 km/h, the power gap shouldn't be that significant. In fact, considering the high speed losses that occur during clipping, and as I mentioned before, Alonso was saying at the start of the race that they have similar power to the others. So it's even possible to say there's no big difference compared to others except for regenaration defecit. (Here, when I say "no difference," I mean something like the power difference Ferrari compared to Merc, there can be a difference for Honda compared to Ferrari, for example). There's also the transmission ratios aspect. It's hard to find accurate information amidst all the empty talk circulating, but it seems to me that a dramatic power increase can't be expected. Even if the engine were running at full capacity, this car wouldn't be able to compete at the front. But we also need to keep in mind that McLaren, after a terrible start two years ago, suddenly became one of the fastest.
Jambier
etusch wrote:
17 Apr 2026, 09:30
Exactly.
Except the vibration, they main issue is that they can't recover enough energy for the electrical part, maybe the ICE lacks power as well but I don't think that "pushing it" will change many things
TyreSlip
TyreSlip
Jambier wrote:
17 Apr 2026, 21:55
etusch wrote:
17 Apr 2026, 09:30
Exactly.
Agreed. At least with the vibrations out of the way, the team can now use Flow-viz and validate if the aerodynamics are working and develop the car from there.
TyreSlip wrote:
17 Apr 2026, 22:32
Jambier wrote:
17 Apr 2026, 21:55
etusch wrote:
17 Apr 2026, 09:30
Exactly.
We'll have a better idea how it'll be during the weekend in Miami. I'm hoping for a close 2nd last. You know actual racing not just lapping.
Bence
Bence
I was just asking because I heard from a close-to-Honda source that the ICE itself is fine, but they were unable to push it beyond 75% (what it means exactly dunno obviously and I didn't want to be more pushy)...
bigblue
I had seen someone say that they'd seen reports (unspecified where) that the PU was 30kg overweight in a forum post, but had disregarded it, as it seemed so unlikely, and no source was given. But now we have an article at Autosport,
Autosport also understands that the engine is up to 30kg overweight.
This is a credible source (though obviously with no attribution to where the info came from), but 30kg just seems way, way over what you'd expect (and Newey didn't throw Honda under the bus on this aspect publicly). All in all, I don't know what to make of the credibility of this.
Bence wrote:
18 Apr 2026, 19:43
We'll see son enough, no point in guessing. I just wonder if they'll choose to run detuned in Miami cause it is the last race for the ADUO.
zoroastar
if there was much positivity coming from anyone in the team id probably be more enthused about the season. nobody that knows anything seems to have much hope for anything other than "some improvements". i dont think theres any way they wont improve, obviously. lets wait and see. hopefully the last 20 races will astonish us all.. in a good way.. already had the other side of that coin.
i saw reports online that the ADUO is selected from ICE power only, but havent seen anything in writing. has anyone else seen anything about it yet?
bigblue
zoroastar wrote:
19 Apr 2026, 04:00
I saw similar. I haven't read the rules though.
the-race.com say the following,
the-race.com wrote:Only one power unit element comes into play: the internal combustion engine. And this is why it is much more complicated to unpick where each manufacturer stacks up now.
Any advantage a team has from better energy harvesting, deployment, efficiency, or more advanced management of energy (which includes control of the MGU-K or better battery technology) is totally outside the remit of what falls under the qualifying criteria for additional development opportunities.
This whole rule set seems crazier and crazier (and over-complex) to me. I suppose the electrical side is homologated and can't be changed whenever desired? To me it makes no sense to completely freeze this and say everyone's stuck with their initial efforts. I read on a forum that changing the PU between seasons is also regulated (I think it was said electrical and combustion alternate year to year), I don't know if that's true, but that also would be crazy. The optimal strategy would be to develop a good engine, run it detuned, then get ADUO to conclusively leapfrog your best competitor. I'd prefer if development was much more open, under the cost cap, else it all feels like manipulation.
