2026 Aston Martin Aramco Formula One Team
zoroastar
Re: 2026 Aston Martin Aramco Formula One Team
bigblue wrote:
19 Apr 2026, 08:26
zoroastar wrote:
19 Apr 2026, 04:00
i saw reports online that the ADUO is selected from ICE power only, but havent seen anything in writing. has anyone else seen anything about it yet?
I saw similar. I haven't read the rules though.
the-race.com say the following,
the-race.com wrote:Only one power unit element comes into play: the internal combustion engine. And this is why it is much more complicated to unpick where each manufacturer stacks up now.
Any advantage a team has from better energy harvesting, deployment, efficiency, or more advanced management of energy (which includes control of the MGU-K or better battery technology) is totally outside the remit of what falls under the qualifying criteria for additional development opportunities.
This whole rule set seems crazier and crazier (and over-complex) to me. I suppose the electrical side is homologated and can't be changed whenever desired? To me it makes no sense to completely freeze this and say everyone's stuck with their initial efforts. I read on a forum that changing the PU between seasons is also regulated (I think it was said electrical and combustion alternate year to year), I don't know if that's true, but that also would be crazy. The optimal strategy would be to develop a good engine, run it detuned, then get ADUO to conclusively leapfrog your best competitor. I'd prefer if development was much more open, under the cost cap, else it all feels like manipulation.
yeah you would think that when they are going into a new formula they may lay off the penalties for using too many components too. the teams that make the rules (and supply half the grid with engines) want to protect their edge for as long as they can, so its like moving mountains to catch up when your team cant get its sh$t together in the beginning.
its all a big convoluted mountain of garbage as far as im concerned. f1 seem ready to toss the real competitive parts of the sport and turn it into a popularity contest on social media. luckily the drivers are talking and the fans arent stupid. i can understand that its always a risk with new rules, but weve been hearing how it was gonna be for 2 years now. formula 1 just wanted to force it down everybodies throats.
the electric side of the PU must be fairly similar as far as components. basically, the batteries are just there being charged and depleted. the icu is the constant power source, and the mguk, control electronics and software are dealing with charging and draining the batteries. i may be wrong, but i assume that the software is the really crucial performance difference in the electric side as long as the mguk is working correctly. and software is probably being ironed out constantly. the team with the most ICU power will have an advantage in charging and recharging though. so it all comes back to the ICU. so it sort of makes sense..
bigblue wrote:
19 Apr 2026, 08:26
zoroastar wrote:
19 Apr 2026, 04:00
The thing is, the electrical side’s power output and regeneration are limited. Anything preventing you from achieving those numbers would likely fall under reliability. Also, the electrical regulations don’t say “go crazy—make as much HP and recovery as possible.” All you really have to work with is efficiency, which is already quite high. Meanwhile, on the ICE side, Honda has said they didn’t achieve their own horsepower goals from combustion and there is no limit except the limit of science.
It's kind of backward when you consider that the ICE is slowly fading in history.
GhostF1
GhostF1
115
bigblue wrote:
18 Apr 2026, 22:09
I had seen someone say that they'd seen reports (unspecified where) that the PU was 30kg overweight in a forum post, but had disregarded it, as it seemed so unlikely, and no source was given. But now we have an article at Autosport,
Autosport also understands that the engine is up to 30kg overweight.
This is a credible source (though obviously with no attribution to where the info came from), but 30kg just seems way, way over what you'd expect (and Newey didn't throw Honda under the bus on this aspect publicly). All in all, I don't know what to make of the credibility of this.
I've seen this figure and it has got to be nonsense. Remember when there were photos leaked of some of the cars weights on the FIA scales? The AMR26 was 13kg above the weight limit or something?
Saying the PU is 30kg overweight would imply the AMR26 is by FAR the lightest chassis on the field, not by a little, but by an enormous margin.
I also saw someone say it's because they added the countermeasures in Japan (after the photos were leaked). Yet the car has only shrunk the gap at every GP, not gotten slower, and those countermeasures were in FP1 and never raced. And I seriously doubt they just tossed in 30kg of deadening material all over the PU..
There's a new number and a new clickbait article every week or two. This one is extreme and got a huge amount of traction in Spanish media (unsurprising). But it's surely borderline nonsense.
dren
228
bigblue wrote:
18 Apr 2026, 22:09
They must have pulled a Jaguar and are racing a V8 block but only using 6 cylinders. #-o
Honda!
ElliotDelgado
GhostF1 wrote:
20 Apr 2026, 02:25
bigblue wrote:
18 Apr 2026, 22:09
I agree with you, i believe all these numbers are just clickbait, 30kg? come on.... all those articles are to generate views when there is no racing
FW17
186
ElliotDelgado wrote:
21 Apr 2026, 07:00
GhostF1 wrote:
20 Apr 2026, 02:25
bigblue wrote:
18 Apr 2026, 22:09
Maybe the author has a problem in understanding lbs and kg
Brahmal
Brahmal
85
This was posted in the Ferrari thread:
CRazyLemon wrote:
16 Apr 2026, 09:04
"If you look up the FIA technical regs on the FIA website, the is a table (in the appendix section, I believe) with ticks for "normal", allowed homologated changes year-by-year, and ADUO changes. Essentially from 2027 onwards, teams are allowed to homologate most ICE-related new components in odd years (2027 and 2029) and electric components in even years (2028 and 2030). So Merc can still homologate a new ICE in 2027."
karana wrote:
17 Apr 2026, 15:01
Appendix C5, 3.3: For the years 2027, 2028, 2029 and 2030, upgrades to the components marked with a checkmark in the table of Appendix C4, in the relevant column for each year, may be carried out. Irrespective of
changes permitted under ADUO according to Article 3.3 of this Appendix, such upgrades must be
introduced for the first Competition of the year when they are allowed and used for the whole
Championship season.
According to Appendix C4, it's mostly ICE-related components in odd years and electric components in even years.
This is to do with homologation, not ADUO related. So ADUO would be on top of this allowed upgrade cycle, apparently.
mzso
mzso
75
FW17 wrote:
21 Apr 2026, 10:50
Or confused the whole car with the PU.
FNTC
FNTC
These new qualy tweaks will hurt Aston, right? Increasing super clipping from 250 to 350kW. In February Newey reportedly said they couldn't even harvest at 250kW. Hopefully that was due to the vibration issues, and hopefully that will be fixed, but not the most promising tweak.
collindsilva
collindsilva
FNTC wrote:
22 Apr 2026, 11:39
There is so much of rumors and talks, engine overweight, engine vibrates, engine underpowered, problems with harvesting, Gearbox not optimised, Chassis is overweight and final car performance is not top notch.
The car has barely run to its full potential, Hopefully if next race should give us clear picture...
collindsilva wrote:
22 Apr 2026, 12:11
FNTC wrote:
22 Apr 2026, 11:39
I agree, we haven't seen the PU at it's limits. Whatever Newey said, you'd have to guess at the why. Was it MGU-K inability or fears of vibrations damaging batteries and or the car.
dren
228
collindsilva wrote:
22 Apr 2026, 12:11
FNTC wrote:
22 Apr 2026, 11:39
It's all the product of a rushed and seemingly mismanaged project. Improvements to be made all over the thing. I still expect massive gains come year end.
Honda!
dren
228
mzso wrote:
21 Apr 2026, 20:00
FW17 wrote:
21 Apr 2026, 10:50
And doesn't understand decimal placement. Or most likely is just full of shyt.
Honda!
ispano6
164
The gearbox is crucial to energy recovery. Expect improvements in weight, durability and vibrations.
V10FURY
V10FURY
These new regulations of 350kw super clipping will really hurt Honda if they haven’t solved that issue by Miami. Hopefully the chassis is better and the vibration issue will be fixed to at least the remotes 80%. Then Honda can run the engine at the full rpm limit/boost and see if they are down 80hp or less than 50hp. I still think they will be a long way off the midfield battle if they are so weak on power and recovery. Miami being a sprint weekend is also not ideal, but at least they extended the free practice 1 to 90 minutes of running. After September the team should start a decent march to catch up to the midfield if Honda can get the ADOU upgrades, and fix the battery / recovery issues. If not this team will need to write off this year and possibly next year as well.
