2026 Aston Martin Aramco Formula One Team
HondaPOD
HondaPOD
Re: 2026 Aston Martin Aramco Formula One Team
diffuser wrote:
02 May 2026, 16:06
You mean he flat spotted the tire?
If you want, yes
FNTC
FNTC
Astons on soft tires cant even pass a cadillac on hards so far...
SchuMassa
SchuMassa
21
Fernando being outpaced by Stroll. What is going on?
EDIT: nevermind, he was probably saving tyres
selvam_e2002
selvam_e2002
-1
this is even worsen than Mclaren + Honda. AMR took a wrong decision to use Honda engine. We need to wait for next rule change in 2030 by the time even Newey also retired. No hope for this team....
search
SchuMassa wrote:
02 May 2026, 18:23
both drivers were more or less constantly told to drop back and cool the car. Most of the time they ignored it
FNTC
FNTC
Alonso got perez on the final lap. Progress, I guess. :roll:
Sedaxel
Sedaxel
Alonso having the most fun he could with this car. Master mind, overtaking in the last laps both Stroll and Checo. Well, at least the car didn't break, and he could fight with someone. Now it's time to develop the concept, since it seems that reliability is more or less fixed.
FNTC wrote:
02 May 2026, 18:36
Yep, it was fun to watch. It's still racing at the back. Engineer kept osay " Ok this is the final attempt, then you're gonna cool."
Also funny is Alonso telling the engineer what mode he should be in. The Engineer said "Alonso go into mode 4". Alonso to Engineer "Stroll is in Mode 4, right? What advantage that give me?". Engineer to Alonso " Yes, you're right". They never mentioned what Mode he was in. Just that he wasn't in Mode 4.
Ashwinv16
imma be honest, its very clear the chassis was what held them back today. Car has pace on par with the Haas despite the worn softs. Just couldnt turn into corners at all so had to be latter on throttle on corner exit. meaning got stuck behind. Also cooling issues meant lot off lift and coast.
Halo not as bad as we thought
OnEcRiTiCaL
OnEcRiTiCaL
Ashwinv16 wrote:
02 May 2026, 18:51
Since it the same package as in February not much play with setup. Probably they also don't want to change much till the vibration,resonance and the reliability issues are not solved .
Ashwinv16
Ashwinv16 wrote:
02 May 2026, 18:51
Also the horrible cornering speeds meant soft tyres lasted way longer than it should have. Maybe they could change the set up to let the car use the tyres more and see if they can bring the pace up.
TyreSlip
TyreSlip
FNTC wrote:
02 May 2026, 18:36
The Cadillac drivers were on the hard tyres. Perez complained he had no grip on them. He was holding up Stroll and Alonso the last 5 laps and it took a double boost to get by him at the end. The race engineers said the engine was critically overheating the last 10 laps and told the drivers to back off and get out of the slipstream.
bigblue
I know the drivers will have wanted to enjoy themselves a bit, but if you're Honda, you wouldn't be happy if they did not comply and they went over what was prudent, due to the possibility of reliability consequences later on down the line.
Anyway, I hope it was OK in the end, they won't want additional work right now (I wonder how many engines to the original spec they've made, and how extensive any ADUO changes would be).
Snorked
Snorked
71
Ted just said on his notebook show on Sky F1 that Honda and Aston had the car in Japan on the rolling road dyno for two weeks, identified the cause of the vibrations, and fixed it.
GoranF1
GoranF1
149
Ashwinv16 wrote:
02 May 2026, 18:51
Car looked quite good in very slow stuff.....
