2026 Aston Martin Aramco Formula One Team
mzso
mzso
75
Re: 2026 Aston Martin Aramco Formula One Team
diffuser wrote:
30 May 2026, 16:11
The other thing is FIA on June 1st will change the CR tests. So the Canada HP was Mercedes's CR edge last hurrah. We will not notice until Spain, because of the nature of Monaco's track.
I highly doubt anything will change... Either because they didn't have a trick in the first place, or the test is useless at filtering with its lukewarm 130°C temperature.
diffuser wrote:
30 May 2026, 19:36
Cylinder Pressure Sensors: Every F1 car runs highly accurate, mandatory pressure transducers inside the cylinders.
Irrelevant. (And I also think it was removed for this year) At 130°C it wouldn't have been likely to show anything.
mzso
mzso
75
SSJ4 wrote:
02 Jun 2026, 12:46
so if newey doesn't turn up this weekend. safe to assume that he's been ill for several weeks is true?
He's not team principal anymore. And they design the car at the office not at the racetrack.
mzso wrote:
02 Jun 2026, 16:50
diffuser wrote:
30 May 2026, 16:11
diffuser wrote:
30 May 2026, 19:36
It wasn't removed, they banned the the frequencies used for pressure verification.
I can see where just heating the PU to 130C in an oven, then performing a pressure test, isn't gonna give you the temperature variations that you normally see in a Piston head and combustion chamber under load. So I am not sure why the other teams agreed. Maybe it was a trade off for getting a test while the PU is running for next year?
Still don't understand how they can come up with a rule to limit something but not think of a way to test it BEFORE implementing it. Then, in doing so, create an artificial imbalance in power and benefit a team for breaking the rules.
mzso wrote:
02 Jun 2026, 17:12
SSJ4 wrote:
02 Jun 2026, 12:46
The reports say he works mostly from home but he does go into the office.
karana
karana
diffuser wrote:
02 Jun 2026, 17:13
mzso wrote:
02 Jun 2026, 16:50
diffuser wrote:
30 May 2026, 16:11
diffuser wrote:
30 May 2026, 19:36
I'm not convinced this will be tested while running next year. The rule for next year still says it will be tested at 130C, just not additionally at ambient temperature as will be the case for the rest of this year.
It is geometric compression ratio so anyone speaking about pressure sensors is crazy or just spouting tripe.
GhostF1
GhostF1
115
diffuser wrote:
02 Jun 2026, 17:13
mzso wrote:
02 Jun 2026, 16:50
diffuser wrote:
30 May 2026, 16:11
diffuser wrote:
30 May 2026, 19:36
This was my thoughts as well. It won't show anything of major interest even at those temps...
The loss of ability to use those pressure sensors in every cylinder for highly accurate combustion readings to tune the operation of the engine and the reg enforced drop in compression ratio basically annihilated Honda's combustion design. It can't safely operate in the manner it did without those sensors or at a much lower CR, let alone both. And god knows how difficult this new fuel is to vaporise or just in general have any properties desired for what they were doing last year. The avenue they went down, was outlawed in every single metric. They caught the nasty end of the stick with these regs
Being 60-70hp down on a circa 500hp engine formula is more than significant. And I genuinely believe the above is why. They are effectively being forced to start again with combustion tech ideas.
ispano6
164
Is it widely accepted that 3d printed piston crowns is what allows for the compression via thermal expansion? And is there any rule actually banning that construction? As long as the prescribed test pass, it's ok?
karana wrote:
02 Jun 2026, 17:54
diffuser wrote:
02 Jun 2026, 17:13
mzso wrote:
02 Jun 2026, 16:50
Another major change that came on June 1st was the additional "Any component, assembly, mechanism, or integrated arrangement of components that is designed or functions to increase the compression ratio in operating conditions beyond 16.0 is prohibited."
So while before June 1st, you could legally make the CR as high as you wanted, as long as you beat the test. After June 1 that is no longer the case. It is now illegal, regardless if you pass the test or not. Meaning if you at some point get caught, it could have ramifications on races all the way back to Monaco 2026.
BassVirolla
PlatinumZealot wrote:
03 Jun 2026, 01:39
Thanks! :lol:
Anybody who says such things has never performed a simple compression test nor studied cam phasing in an engine, and pretends to know how a cylinder fills and compresses with air. #-o
Rodak
Rodak
37
BassVirolla wrote:
03 Jun 2026, 07:27
03 Jun 2026, 01:39
Thanks! :lol:
Yep. I thought and hoped this 'discussion' had ended but seems like not the case. As to pressure sensors, per the 2026 FIA Technical Regulations:
5.3.7 In a Cylinder Head, only inserts approved by the FIA Technical Department will be allowed.
The total volume of the inserts listed in a. to c. below cannot be more than 3% of the total
volume of each Cylinder Head and these must be confined to:
a. Conventional valve seat inserts
b. Conventional valve guide inserts
c. An insert concentric to the spark plug axis with a maximum outside diameter of 15mm
An additional allowance of 1% of the total volume of each cylinder head is permitted for
inserts other than those mentioned above, but none of these inserts can be exposed to the
combustion
mzso
mzso
75
diffuser wrote:
03 Jun 2026, 06:01
karana wrote:
02 Jun 2026, 17:54
diffuser wrote:
02 Jun 2026, 17:13
That's why Ferrari was disqualified from the 2017-18 seasons, right? Hah! Nope...
As long as they can't test and prove it, it's a free area of development, no matter what the rules say.
mzso wrote:
03 Jun 2026, 23:49
diffuser wrote:
03 Jun 2026, 06:01
karana wrote:
02 Jun 2026, 17:54
Anyways, if you look at the ICE HP difference, it isn't the deferentiator. Nor is it why Honda don't have the power to accelerate the drag that the car makes at 262 KPH to 272KPH without the aid of the MGU-K.
zoroastar
https://www.motorsportweek.com/2026/06/ ... er-livery/
looks like a random new monaco livery for the weekend.
zoroastar
diffuser wrote:
02 Jun 2026, 09:42
zoroastar wrote:
02 Jun 2026, 04:55
hollus wrote:
01 Jun 2026, 20:19
So, ICE power.
From this video:
It looks like the Astons are about 4.5% down in top speed while on ICE alone, compared to most others. Feel free to derive a more precise delta if you wish. That is good enough for government work, me thinks.
Assuming equal drag and with power drag changing with the cube of speed, we get that the Astons ICe delivers about 87.1% of th epower of the average other car.
13% deficit on ICE alone. Not quite the 100 HP rumored, but a lot! Is that like 65 HP?
They'd of course also be missing durng acceleration...
it seems like theyve had a pretty good idea about hp numbers since about 2 races in. whoever "they" are. i wonder what they say about average HP per lap with deployment/charging going on.
So that is an interesting question. I think I'd like to know how much each PU manufacturer recharge in a lap. In quali, any given lap of a race and the average recharge during all the laps of a race. It should be something in live timing but it's not.
yeah the complete absence of any data on batteries during races is pretty surprising. i wonder if they decided not to show it because itd show how much advantage some engines have over others. instead theyre just keeping everybody in the dark. this season is the weirdest that i can remember.
