diffuser wrote: ↑17 Feb 2026, 05:08
mzso wrote: ↑17 Feb 2026, 02:51
Leon Kennedy wrote: ↑17 Feb 2026, 01:44
A very particular solution, two separate combustion chambers (in fact they should have given the Nobel Prize if they had geometrically increased the
ratio from 16: to 18:1 with only the thermal expansion and related problems). However, according to the rules, you must have a 16:1
ratio at all times. They wanted to be smart because there weren't sensors to measure the hot
ratio and now maybe they want to install them. Basically, by regulation you can't do it, but no one can prove it without this sensor. But evidently some engineer leaked the solution (thank goodness, otherwise everyone would have been unaware). The bad thing is that they did it with the approval of the FIA which had allowed this without telling the others according to the rumours, one thing if it were true would be embarrassing.
A pre-combustion champer is nothing new though. (Not sure why you called it microcamera)
And the rules explicitly say that the compression
ratio is to be measured at ambient temperatures. And that's that. Everything else is fair game.
Except they only added “measured at ambient temperature” in Oct 2025. That’s what triggered all the protests. If you write a rule where none existed before — just to save manufacturers money and make it easier for new teams — you shouldn’t create a giant loophole that requires ten times the research and development costs to overcome compared to keeping the original no-limit CR. It’s absolute madness.
This IMO is the most controversial thing of all.
With hindsight today, someone could argue that "ambient temperature" parameter was added so late just to give the Mercedes trick some more creditability or legality.
This is the main reason i think why (IMO) FIA and FOM will be forced to align with the majority of engine manufactures and rectify this situation.
As i see it, even if it is not said out loud by the manufactures, this is a case that manufactures may have threatened behind closed doors to go to court over this, if FIA doesn't rectify the situation, and then FIA will have to explain in court under what circumstances exactly they decide to add the "ambient temperature" parameter so late, and if by then, they already had communications with Mercedes regarding what Mercedes is trying to do.
The whole thing if it goes to court will look very bad IMO for FIA in the public eye.
That's why i believe this is a case that all 4 manufactures will be willing to take to court, and on the other hand Mercedes will actually do nothing if FIA changes the measurement procedures and just accept it.
They know that if this goes to court, will probably not look good for them either, because some heavy lobbying (hypothetically) may have been involved for that "ambient temperature" so late introduction.
I may be wrong ofc, and the things i am saying are all just speculations, not facts, but this is how i see it tbh.
