2026 Aston Martin Aramco Formula One Team
Re: 2026 Aston Martin Aramco Formula One Team
mzso wrote:
27 Jun 2026, 16:15
OnEcRiTiCaL wrote:
27 Jun 2026, 14:32
You need real test and confirmation about the package and new parts.
Maybe that is what the second half of the season be about.
That wouldn't explain why they're putting everything in one major update. The one thing that would explain that is a major change at the base. Something they've decided is wrong and changing it would effect everything on top.
FNTC
FNTC
diffuser wrote:
27 Jun 2026, 17:02
mzso wrote:
27 Jun 2026, 16:15
OnEcRiTiCaL wrote:
27 Jun 2026, 14:32
Maybe changing the chassis with mounting solutions for the vibration issues (instead of the current bandaids), and/or changing those rear suspension mounts to the rear wing pylons? Will see.
FNTC wrote:
27 Jun 2026, 17:03
diffuser wrote:
27 Jun 2026, 17:02
mzso wrote:
27 Jun 2026, 16:15
I'm not an expert, but my understanding is that modifying the ICE mounts to eliminate vibrations is similar to a combination of balancing wheels and tuning a guitar. You wouldn't really notice the difference in the final product unless you knew what to look for.
Maybe the suspension but they've changed those in regular upgrades....
They seem to have cooling problems. So moving radiators or switching types?
mzso
mzso
75
diffuser wrote:
27 Jun 2026, 17:02
mzso wrote:
27 Jun 2026, 16:15
OnEcRiTiCaL wrote:
27 Jun 2026, 14:32
Uh, what? It doesn't need to explain it. One big update to better use the resources, as they said. They'll probably bring smaller ones as they evaluate it.
Jambier
NAPI10 wrote:
27 Jun 2026, 16:23
Some positive words from Alonso…seems he has decided to stay another year with the team :D :D
What he said was interesting also in terms of non driving.
He will take some stakes in the team I believe same as Newey, maybe one day be a team manager.
And race in other categories, but anyway I think he will drive 2027 at Aston, maybe 28
Petebass
Petebass
FNTC wrote:
27 Jun 2026, 16:21
9 tenths off the slowest Cadillac in P20, 1.7 sec off Q2 and P16, and 2.4 sec off P10. :roll:
In a short circuit...
TyreSlip
TyreSlip
Jambier wrote:
27 Jun 2026, 18:27
NAPI10 wrote:
27 Jun 2026, 16:23
I said it earlier, but Alonso should do either two more years or retire now. It is pointless to race one more year when next year will be another transition year.
TyreSlip
TyreSlip
Petebass wrote:
27 Jun 2026, 19:42
FNTC wrote:
27 Jun 2026, 16:21
Constant car upgrades from the other 10 teams will tend to do that.
Rodak
Rodak
37
I'm not sure what you mean by modifying the mounts, but from the 2026 Technical Regulations:
5.6.17 Engine (ICE) mountings may only comprise six M12 studs for connection to the survival cell
and either four or six M12 studs for connection to the gearbox case. These studs may be
fitted on the survival cell, power unit or gearbox case, their installed end must be M12 and
their free end may be a different diameter.The six mounting faces of the studs for connection to the survival cell must lie at [XPU, Y,Z]=[0, ±270, 25], [0, ±360, 270] and [0, ±190, 440]. All six of these studs must be used.
The four mounting faces of the studs for connection to the gearbox case must lie at [XPU, Y,
Z]=[480, ±125, 25] and [480, ±265, 360]. All four of these studs must be used. Optionally, an
additional two studs may be used, provided their coordinates are at [XPU, Y, Z]= [480, ±150,
140].
A tolerance of +/- 0.2mm will be permitted on all of the above dimensions, all dimensions
refer to the centre of the studs. All dimensions in this Article refer to studs fitted
symmetrically about the car centre plane.
Rodak wrote:
27 Jun 2026, 20:00
140].
The bolts that connect the ICE to the chassis are connected to the ICE mounts. Those bars that come off the ICE and form a triangle over the heads are Engine mounts. The connect to the chassis on one side and the gearbox on the there. Apparently they can make minor size changes to those bars in spots and it absorbs vibrations. That what I read anyways.
zoroastar
Rodak wrote:
25 Jun 2026, 21:20
zoroastar wrote:
25 Jun 2026, 08:56
honda are going to need to find more than +/_ 70hp. with the changes for 27-28 the ICE is going up even further. hopefully the fact that honda voted for it means that they believe itll help as opposed to leaving them further behind.
FYI you can generate the ± symbol by using holding down alt key and entering 241.... ° symbol is alt-248.
thanks man. im on mac though and its something different. +/- is the way i shoulda typed it. one day ill learn the shortcut on here
zoroastar
Jambier wrote:
25 Jun 2026, 21:51
mzso wrote:
25 Jun 2026, 16:41
Jambier wrote:
25 Jun 2026, 16:14
Regarding engine:
- Audi brought the first ADUO in Spain. A bit of gain, not so much
- Ferrari will bring in Austria the first ADUO, less than 10 HP, and probably another one less than 10HP
- Mercedes will bring reliability upgrade for engine
Honda has split the team:
- They are working already on the 27' engine given all the issues, power down, weight etc... compare to the other
- And they will bring only one ADUO upgrade. They won't use the other one.
They speak about a "reasonable upgrade" but not a game changer: My prediction is that this B version of the engine will improve every aspect, and bring only 20HP to the engine.
Then there is the chassis upgrade as well, but the most realistic is to fight with Williams at best, and beat Cadillac.
I don't expect much.
Sadly I expect 2027 to fight for the points and not more. I have more confidence for 2028/2029
So these are your guesses then?
No way they won't use both ADUO upgrades, especially knowing that the second one only needs to be submitted next year by march 31 IIRC.
This is what Shintaro Orihara declared. They will only do one engine upgrade this year arround summer.
that seems like a huge waste. the aduo also comes with extra money, which theyre almost definitely gonna need.given the timing of the updates and the need to redesign things for 27 maybe it just doesnt make sense. it remains to be seen how a team can recover from such a deficit under this cost cap. theyre down by 30 mph (50kph) on the straight here, which just sounds bizarre. up until now the teams and fia seemed pretty sympathetic to hondas situation but if newey brings a killer b-spec thatll probably change
can they take the money for the 27 engine without bringing the second aduo upgrade? these rules seem like a complete cluster #$%^. its like theyre making things up as they go
Jambier
Don’t know if they can keep the extra money allowance
But since there is a budget cap all those limitations are making no sense.
Let it free like on chassis side, and just let the cap. Then they can plan and work properly to deliver upgrades
OnEcRiTiCaL
OnEcRiTiCaL
diffuser wrote:
27 Jun 2026, 15:16
OnEcRiTiCaL wrote:
27 Jun 2026, 14:32
FNTC wrote:
27 Jun 2026, 00:12
They are not even trying, just waiting for the B-spec. Will the new chassis/aero package be at Spa or Hungary? And the engine? Maybe after the summer break...
Is doesn't matter honestly! Aston Martin act like they never was in f1. Even more... is not the first time that they delayed things or skip small updates. I understand that for Alonso doesn't matter if 8th or 22nd. But end of the year in points is matter a lot in every aspect. In F1 and overall in competition motorsport, if you bring nothing, you learn nothing! Doesn't matter how good is the windtunnel, cfd etcetera. You need real test and confirmation about the package and new parts. But who could this know better than Aston from the past 2 years of fails,not working parts,correlation issues 🤔
They still have a lot of drivability issues they need to solve. They can address those through software. Software can be changed as needed until qualifying, so I'm sure they're working on it. I'm just not sure how much driver time that will take up during FP.
Thousands of sensors on that car when they test something, drivability issues cant be a problem, even if Fredy with feet is the pilot. They had such a long time, almost summer brake and still cant complate a race because of gearbox, because of engine, because of battery, because of blabla. Yes im pretty sure is will be better, but soon again new rules and regulations .
OnEcRiTiCaL wrote:
28 Jun 2026, 01:26
diffuser wrote:
27 Jun 2026, 15:16
OnEcRiTiCaL wrote:
27 Jun 2026, 14:32
Shintaro Orihara was asked what he thought Honda would do if the FIA went to a naturally asperated v8, he said he thought Honda would pull out of F1.
