collindsilva wrote: ↑13 Feb 2026, 06:37
Ashwinv16 wrote: ↑13 Feb 2026, 06:27
OnEcRiTiCaL wrote: ↑12 Feb 2026, 23:21
They not,Mike said there is a gap and only way to get closer is to work harder. Is definitely some isse with the energy side.
Yeah Mercerdes said the same thing in 2019 when Ferrari topped the time sheets and then wiped then floor once the season started. We got issues but there is no way we 4 seconds off. Either Honda hasn't communicated their plan properly or they just saying it to have people look away in what is a very controversial car and engine design outside the compression
ratio issue. Not saying its going to be great but I don't expect a disaster. Remembrance the bahairn track temps are not anywhere near what the cars will be at for 95% of the races including the temperature at the Bahrain race itself. It is butt clenching but I don't think there is too mcuh to worry yet. Let's see hwo things go today.
Also, we still got another 4 days of testing, the Engine Homologation date is end of FEB, there is still time to refine the package. It is also to be noted that, this is the first time AMR is working as a works team, everything built inhouse, the change in rule, new facility etc. It requires time and patience to be No 1 team...
Yeah I am hoping at least let this be one of the few places where we keep some hope but at the same time stick to the facts and trust the process. Speaking of which aside from the engine theres a few things to look at.
- The rear seems to work really well right now despite the aggresive suspension. Its very Planted in the medium speed corners and its getting good traction out of the slow corners
- there is severe understeer in the front likely due total the very low downforce front wing. It doesn't look like the front wing is currently the correct spec.
- braking is an issue again highlighted by the detuned engine or kers but if not it soemthing to work on
- front suspension is the biggest concerns as it seems too rigid aka very stiff and even with set up changes it might need a bit of rethink. Its clear that seems to cause most fo the problems unless there is a more loaded front wing. Alonso couldt ride the kerbs, something that needed this season as ground effect gone. Both drivers could trust the car to turn in to the corner at all during testing despite getting the traction out the exits. So Yeah
- Tyre wear again looks better than last year but still below top team standards although to early to tell.
