Improvements needed overnight. Ham says car is "night and day" different to Austin & difficult to extract performance. But Toto reckons a clean lap would have already put them top 3 so the performance is there..
F1.com is putting Merc up to second based on what we have seen so far so if they make an overnight improvement then they would be looking quite good. Qualifying is very important. Difficult to pass here.
https://www.formula1.com/en/latest/arti ... BLPMZ.html
Beware of T-Rex
RonMexico
AMuS reporting the plank wear in Austin was closer to 1mm ... Hmmm
RonMexico wrote:
28 Oct 2023, 14:50
Which is also what formu1a.uno suggested - that Merc's plank wear was more than Ferrari's (0.2mm)
CHT
CHT
-7
28 Oct 2023, 14:53
RonMexico wrote:
28 Oct 2023, 14:50
illogical for anyone not to dispute 0.05mm if it was true.
RonMexico wrote:
28 Oct 2023, 14:50
“One hears of an excess of two millimeters.”
I couldn’t be less direct in a statement if I tried; laughably non-committal.
Hammerfist
Hammerfist
Hamilton sounds like a drama queen sometimes. All cars dont feel great at this track. They never do. The car being good relative to the others is what matters. Already im not seeing the big top speed delta compared to Max’s Redbull. Things look promising imo.
Luscion
Luscion
145
RonMexico wrote:
28 Oct 2023, 14:50
Does AmuS have a source or is this just the "i hear rumors in the paddock"?
Luscion wrote:
28 Oct 2023, 18:39
RonMexico wrote:
28 Oct 2023, 14:50
Amus is a fairly reliable source, especially regarding Mercedes. You aren't going to see them name their source for obvious reason...but they are quite close to Mercedes. I would hesitate to dismiss it out of hand. There are some things you can't do as a reporter which is why things are written as they are.
Beware of T-Rex
Big Tea
99
Does it matter? Out it out you cannot get anymore disqualified than disqualified. There are no shades of failing the test it is still a fail
napoleon1981
napoleon1981
Luscion wrote:
28 Oct 2023, 18:39
RonMexico wrote:
28 Oct 2023, 14:50
No source needed. The plank by regulation can wear 1mm. The plank has to be 10 +/- 0.2mm when new and 9.0 at the end of the event. So a plank can wear 1.2mm if a team looks for the most thickness at the start. So the merc plank was very likely worn more than 1.0mm. But atleast 0.9mm if the plank was 9.8 to start.
Rootsap
Rootsap
It looked pretty promising in Q2...
Mansell89
Mansell89
I feel like Merc will be stronger tomorrow but unfortunately it will be chasing Max home once he passes the Ferraris
Spoutnik
Spoutnik
It will be very hard to overtake Perez/Ricciardio and the Ferrari + Max. All these cars could go to >=350kph today
Again Im afraid qualy will compromise Merc. But I think it should be a good race
Lewis is probably getting a +5 place penalty. He didn't lift for the yellows in Q1 through T1/T2
