saviour stivala wrote: ↑06 Nov 2025, 11:13
. . . It seems these recovery when cornering are new, meaning this mode was not there before.
As shown by
Wuzak above - there is NO MENTION of harvesting "during cornering" in the Technical Regulations. The Technical Regulations do mention harvesting in "partial load".
They also provide a formula giving the limits for partial load harvesting at any given load demand. (The Regulations (erroneously) use the term "engine power" to indicate the partial load demand. The term "PU output", "driver demand" or "power demand" would be more correct.)
If you apply the formula above, using a few examples of "driver demand", you can calculate roughly how much harvesting will be available for each.
My interpretation of the regulation is "for any driver demand less than full throttle, the control system may harvest at a rate given by the formula given in 5.4.5. For example if the mode selected is "maximum harvest" and the driver demand is 150 KW to the tyres, it is permitted to use fuel at the rate of 2336 MJ/hr which is equivalent to approximately 325 KW from the ICE. Since the driver only wants 150 KW at the tyres, the MGU-K will harvest at 175 KW.
I would be interested to hear your interpretation of this regulation (if different to mine).
