Ferrari SF-24
Re: Ferrari SF-24
yooogurt wrote:
Fri Sep 20, 2024 2:16 pm
Has anyone seen if it flexes?
An ok amount from an onboard with Carlos.
Hard to judge on this track where we don't have many 330 to 100 breaking zones.
KimiRai
KimiRai
250
Re: Ferrari SF-24
Re: Ferrari SF-24
The best, most relevant photo comparison of Imola (used in Monaco and Hungary) and Singapore spec flaps. Note the new downward tapering of the fixed top flap element on the nose, previously completely flat
Full article https://www.formulapassion.it/f1/f1-ana ... -molto-piu
FlYiNgIcEmAn
FlYiNgIcEmAn
Re: Ferrari SF-24
Here you can see it a bit
https://x.com/AnaFerrariHeart/status/18 ... ImOPA&s=19
Re: Ferrari SF-24
Vanja #66 wrote:
Fri Sep 20, 2024 9:29 pm
https://storage.googleapis.com/fp-media ... gapore.jpg
A lot more aggressive in the middle.
I don't think there's less surface at any point, this wing drops more aggressively from it's highest point, but once it "catches up" to the old one it switches to gentle linear drop, similar to the old one.
sucof
Re: Ferrari SF-24
To me it seems even the nose has a new shape, kind of flatter and more pointy. I am not sure if it is because of the different lighting though.
Re: Ferrari SF-24
sucof wrote:
Sat Sep 21, 2024 8:46 am
I see what you mean, but it really is just different light reflections. I don't think they have too much room to change the nose cover shape, crash structure underneath is very close to it
bluechris
Re: Ferrari SF-24
Now with the onboards, if you see MCLaren front wing flexing and you compare it with the new Ferrari one you will see that Ferrari compresses a lot less. They have to much left on the table on this for sure but at least they started to use it.
Emag
Emag
84
Re: Ferrari SF-24
bluechris wrote:
Sat Sep 21, 2024 11:07 am
I don't think that's the case, but the outboard (the part which is most visible on onboards), is a lot less loaded on the Ferrari wing compared to McLaren's wing so you see less movement.
It could be that they can't run a wing that is similar to McLaren's because it might be messing up the flow downstream. They have had a less-loaded outboard section all-season so I wouldn't be surprised if the platform works at best with the wing like that.
Andi76
Andi76
426
Re: Ferrari SF-24
Vanja #66 wrote:
Fri Sep 20, 2024 2:03 pm
The transition tip of the 4th flap (mid span) is seriously cranked up, leaves an impression of a section that might get substantial local separation but it's highly unlikely. There might be some cross flow there, inwash on the bottom and outwash on top
https://cdn-7.motorsport.com/images/mgl ... detai.webp
https://cdn-5.motorsport.com/images/mgl ... detai.webp
For some reason, there was a lot of flow vis on the rear, it doesn't look like there's anything new, but there may be some subtle beam wing changes. Looks to me like the tips of the second element are smaller now, very subtle change.
https://cdn-1.motorsport.com/images/mgl ... sf-24.webp
amr wrote:
Fri Sep 20, 2024 1:04 pm
Interesting pictures here
In the first picture (supposedly new on the stand) - the top flap has the carbon fibres arranged horizontally and the second one vertically
In the second picture (old) - both top flaps have the carbon fibres arranged horizontally
In the last picture (supposedly new but on track) - both top flaps have the carbon fibres arranged vertically.
I guess they are really trying things out to achieve the flexibility they need.
That's not fibre direction, what you see as grey and black is twill reflection. Fibres are actually under slightly different angles on 4th flaps, while 3rd flap is almost the same
The "curl" at the end of the front wing is somewhat reminiscent of the end plate extensions used in the early 1990s and certainly has a similar purpose with regard to the front wheel wake, albeit in a different form as its in a different position.
hollus
Re: Ferrari SF-24
Some enormously long posts that were about flexing wings in general, and not about this car, have been moved to their obvious home thread.
A reminder to please make the extra effort to keep the car threads on topic.
Rivals, not enemies.
Re: Ferrari SF-24
Excellent illustration of new wing from Rosario Giuliana
