deadhead
68
Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
I just watched a video on permanent magnet vs. induction electric motors and made me think about what kind are used in F1.. does anyone here know?
From what I saw in the video, I guess having both is best case scenario, but I doubt that's the case, so I'm guessing they are using permanent magnet because they can deliver more power at higher speeds.
saviour stivala
saviour stivala
53
According to CAR MAGAZINE - (CARMAGAZINE.CO.UK OF 2020) MGU is a permanent magnet brushless AC electric motor.
JRodrigues
JRodrigues
16
Audi has their on the benches and running full GP distances.
650
deadhead wrote:
04 Apr 2024, 04:36
to not impede gearshifts the MGU-K needs high acceleration/deceleration ability 10000-11500 crank rpm in c.5 millisec
the induction machine can never be responsive enough for this
interestingly the latest plan for 2026 is to continue having 8 speeds (6 was predicted)
the rpm drop being 40% more with 6 speeds it's likely there's a shift response issue (with 6 speed & 2026-size MGU-K)
clownfish
clownfish
Does anybody happen to know what method current F1 engines use for their rev limiter(s)?
Just curious after some chat on various broadcasters around Gasly's engine failure.
I had a search but couldn't find anything concrete for the V6 formula.
gruntguru
gruntguru
569
Depends what you mean by "method".
They would have several options available to them.
  • Cut ignition. It is almost certain that Ignition cut is not used - unless fuel is simultaneously cut. Ignition cut alone wastes fuel.
  • Cut fuel (skip injection). Fuel cut may be the most efficient. Leaving the throttle and boost in place ensures that firing events that remain are at the highest possible efficiency.
  • Intake throttling. Throttling is easy to do - the ECU already has this capability.
Ignition cut or fuel cut would involve cutting ignition or fuel events in some order that shares the cutting over all cylinders. The number of "cut events" would start with a small number at some rpm just below the limit, and progressively increasing to 100% cut at the rpm limit.
Vappy
Vappy
Quite the spectacle to see the renault engine die after doing 13K RPM. I would imagine the tolerance levels (strength) is on the limit of engine use range, rather than build a bit stronger for that extra bit of reliability and pushing it harder for longer under certain conditions (strat mode, etc).
bananapeel23
Tommy Cookers wrote:
01 Jul 2024, 14:02
deadhead wrote:
04 Apr 2024, 04:36
I'm so happy they went for an 8-speed. A 6-speed would make these miserably slow cars even slower.
Jejking
Jejking
Does anybody have any hard(ish) data on total fuel consumption through races of all time but especially in this era? I recall an interesting graph live on telly during especially the 2014 season where the consumed KGs were at full display, although the starting weight was never broadcasted (of course).
ENGINE TUNER
ENGINE TUNER
25
Jejking wrote:
17 Jan 2025, 00:24
I remember a race in 2014 or 2015 where Merc won a race using about 85kg of fuel. The v10s were using about 220L of fuel during refueling. The 2.4Lv8s used about 150kg. Sorry for the mixed units.
650
Jejking wrote:
17 Jan 2025, 00:24
Does anybody have any hard(ish) data on total fuel consumption through races of all time but especially in this era? ..
the gas turbine F1 Lotus 56B has 350 litres fuel tankage
the F1 Alfa Romeo 159M has iirc 68 imperial gal tankage and did 1.5 mpg
the Novi (at Indy 1952 etc WDC-legal) had 85 US gal tankage
