Possible solutions to improve the 2026 Engine Regulations
gearboxtrouble
gearboxtrouble
Re: Possible solutions to improve the 2026 Engine Regulations
bananapeel23 wrote:
30 May 2026, 22:52
Fuel flow will almost certaintl be set at 3300MJ/h. That’s a 10% increase.
In that case we're looking at 65/35 in reality. That would be a really good step forward to making this a normal racing series again if they can manage that. I hope you are right.
karana
karana
gearboxtrouble wrote:
31 May 2026, 22:08
bananapeel23 wrote:
30 May 2026, 22:52
No, if we assume a 400kW ICE, we have currently a 53/47 split. A 450kW ICE (an increase of even more than 10%) with a 300kW MGU-K would be a 60/40 split.
bananapeel23
34
karana wrote:
01 Jun 2026, 00:00
31 May 2026, 22:08
bananapeel23 wrote:
30 May 2026, 22:52
Thing is that F1 can say the engine is as powerful as they want in order to get the 60/40 split.
The ICE isn’t actually 400kW. Most seem to think they are between 415-425kW. If you add an additional 10% fuel flow, you end up at ~455-470 kW. Nominal ICE power can then be set at 450kW, since that is about where the worst PU is likely to end up and roughly in line with how the nominal power is set in relation to fuel flow today.
450kW ICE + 300kW MGU-K works out to a perfect 60:40 split. Hence 3300 MJ/h is likely to be the number they go with for 2027 unless they increase power by some other means than just fuel flow.
What could increase power apart from fuel flow is unclear. Perhaps slightly denser fuels, higher boost or a higher compression ratio. Realistically they will probably just increase the fuel flow, however.
WardenOfTheNorth
Stu wrote:
30 May 2026, 20:14
clownfish wrote:
30 May 2026, 18:26
Are the teams currently running full fuel tanks in the race?
Who knows!? They are unlikely to tell us due to competitive advantage.
What I would say is that McLaren are likely to be on the small side as far as fuel tanks go purely because of their 100mm shorter wheelbase.
Wouldn't that mean they'd be risking being short on fuel though? No-one is going to have a bigger tank than they need surrely?
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
Schumix
Schumix
Does anyone know when the FIA will publish its decision regarding which team is entitled to the ADUO concessions?
I was thinking that this decision was supposed to be released before the Monaco GP, which officially kicked off today with the press conférences.
Good question.
Beware of T-Rex
gearboxtrouble
gearboxtrouble
I wonder if the ADUO announcement is held up as part of the negotiations to change the 27 engine regs by increasing fuel flow. Ferrari and Audi certainly seem to base their objections to the 14% fuel flow increase on what it means for the ADUO usage this season.
EDIT - AMUS just said that the FIA was holding the ADUO allowances as a bargaining chip to force Ferrari and Audi to agree to the 2027 rule changes
https://www.auto-motor-und-sport.de/for ... -geschenk/
Schumix
Schumix
05 Jun 2026, 15:29
Ah, that’s very interesting information.
I think I finally understand why Red Bull (Max) and Mercedes (Piastri) are campaigning for engine modifications to take effect in 2027, changes opposed by teams likely to benefit from ADUO concessions.
For many F1 fans, a team’s success now hinges on its ability to influence FIA decisions.
ScottB
ScottB
Schumix wrote:
05 Jun 2026, 22:53
05 Jun 2026, 15:29
As it ever has been.
Pick any era, you will find championships turned by FIA tech decisions; Renault mass dampers, Michelin tyres, flexi wing tests and on and on...
Luscion
Luscion
153
FIA announces progressive changes for the Power Units for the next three-year period, which will be split as follows between ICE and electric.
ICE/MGUK
2026 53/47
2027 58/42
2028 60/40
bananapeel23
34
31 May 2026, 22:08
bananapeel23 wrote:
30 May 2026, 22:52
3150MJ/h in 2027 and 3400 MJ/h from 2028 is surprising to me. I expected a smaller fuel flow bump.
FNTC
FNTC
I'm guessing the reasoning for only 5% increase in ICE power in 2027 is they don't need a bigger fuel tank, since they are probably well into designing next years chassis. Which makes sense. Then they just cap the MGU-K power by 50kW to get 58/42 ratio. But it seems like the overtake mode will change dramatically next year, with 50kW or 67hp more than the car in front if within 1 sec?
Edit: I just saw Thomas Maher saying they also agreed to reduce the race distance at some races in 2027, so pretty sure they will keep the same tank size then.
