This means Red bull can load him with 10 kg less fuel or 10 kg more fuel and tell him to beast the hell out of it.
Anyone disagree? F1 is becoming a farce again - the lightest driver in the fastest car wins...
With 0 fuel; Webber+RB7 = 640kg. Vettel+RB7 = 640kgCaptain Nemo wrote:Precisely the minimum weight is without fuel, therefore you use the lighter driver to your advantage 10kg is a huge advantage, which is why generally Webber cannot catch him..
=D>Giblet wrote:So Massa should be the quickest driver then? Alonso is bulkier and taller than Massa who is pretty diminutive, but regularly out qualified and out raced.
They should really be trying to get Danica Patrick then. Shes like 100lbs! Or Zanardi, no legs at all. Imagine the packaging possibilities!
And that ballast would be of little use since we have fixed weight distribution this year.raymondu999 wrote:Basically Nemo; Vettel has to have 10kg of metal put into his car so that he and Webber are the same weight in their cars. That's the easiest way I can think of explaining it.
