Hi!!
Not sure where to post this, so feel free to move/delete/merge (as if you need my permission anyways, haha).
I don't understand mechanically how can Vettel's Issue happen. As far as I know, it's a mechanical steering, electrically assisted. Meaning the wheel is connected to a rack/pinion which turns the wheels.
If this is the case, how can it happen that the centerpoint moves? I understand that there was no problem with the suspension, toe was as it should, etc. There would need to be some sort of slip in the steering shaft or something like that.
Does anybody have more information?
Cheers!
