djos
86
Re: A shameless image thread for the enginephiles
Post by djos » Mon Jan 08, 2018 1:00 pm
gruntguru wrote:
Mon Jan 08, 2018 9:18 am
djos wrote:
Mon Jan 08, 2018 4:17 am
Jolle wrote:
Sun Jan 07, 2018 11:24 pm
Uhm... what intercooler?
My thoughts exactly, it's just a carbon tube with an air filter attached.
That's the air intake. The "intercooler" is (isn't) the piece of aluminium tube running across the engine bay in front of the engine.
my bad, yes just a nice looking intake plenum, no visible intercooling present.
The impossible often has a kind of integrity which the merely improbable lacks.
Post by wesley123 » Mon Jan 08, 2018 1:07 pm
Why would they ever not run an intercooler? Looking at the pic it's not like space is a constraint
Singabule
Post by Singabule » Mon Jan 08, 2018 1:26 pm
Not needed, its an alcohol dragster setup.
flynfrog
Post by flynfrog » Mon Jan 08, 2018 2:41 pm
roon wrote:
Sun Jan 07, 2018 11:13 pm
An engine with what's left of a corvette attached:
http://speedhunters-wp-production.s3.am ... 00x800.jpg
I am pretty sure that is the kinsler ITB setup. I have been really good if anyone would like to get one for me.
dren
173
Post by dren » Mon Jan 08, 2018 6:25 pm
Volvo D13 Turbo Compounded Diesel
Honda!
roon
135
Post by roon » Mon Jan 08, 2018 6:33 pm
https://www.volvotrucks.us/-/media/vtna ... 2E59658FB8
One unusual feature on this one is the axial-entry, tangential-exit on the turbine to accommodate the PTO.
Also, there's a bellows joint right at the turbine entry. The turboshaft seemingly quite long if directly connected to the compressor i.e. one continuous shaft. Is such a large high-RPM device with a flexing region in its middle a unique achievement?
High res image here for inspection:
http://www.sae.org/dlymagazineimages/14 ... 95_ACT.jpg
roon
135
Post by roon » Mon Jan 08, 2018 6:37 pm
More of that sweet single-channel low-restriction intercooler.
J.A.W.
52
Post by J.A.W. » Tue Jan 09, 2018 2:10 am
r101 wrote:
Tue Dec 19, 2017 1:14 am
J.A.W. wrote:
Mon Dec 18, 2017 11:30 am
r101 wrote:
Sun Dec 17, 2017 2:07 am
I remember this! It was on NR750 and 125 HP from that displacement was kinda big deal in 1992.
Hardly.. unless..if by epic, you mean epic fail.. & Yamaha had a 125hp 750 on test - in 1972..
I did not write 'epic' i wrote 'kinda' - as it was totaly new architecture and the engine from the get-go was at (or near) the top for that displacement (not talking racing bikes here or something that was on test bench). The biggest fail on that engine (IMHO) was that it was too heavy.
And, please tell me as I was driving lot of bikes at a time and cannot remember myself, which bike that was sold that year made 125 hp from 750 ccm in 1992 'epic fail'?
Huh? Dunno quite what you are trying to express there.
In 1972 Yamaha had shown their GL 750 4 cyl EI 2T roadbike, but chose to to offer the design for sale - solely as a racing machine, & sold a dud 750 4T twin as the streetbike, instead.
The NR Honda effort was an "epic fail", both as a race bike, & as a production streetbike, no question.
Sturmbannfuehrer Dr von Braun sez..
"Oberste Prioritat hat es Londoner Terror zu vergelten. Und danach, der Mondflug!"
Mudflap
47
Post by Mudflap » Wed Jan 10, 2018 11:29 pm
A better intercooler.
With vortex tubes ofc.
Si vis pacem volve velox
roon
135
Post by roon » Thu Jan 11, 2018 2:35 am
Could have a much shorter pipe if they'd simply drilled a clearance hole through the radiator. Running it through the headlight seems like an odd choice, you'd have to run sealed beams to make sure headlight fluid doesn't get sucked in.
Jolle
68
Post by Jolle » Thu Jan 11, 2018 11:42 am
https://static.carthrottle.com/workspac ... b3c06d.jpg
An intercooler without a turbo? Interesting...
Zynerji
Post by Zynerji » Thu Jan 11, 2018 2:33 pm
He's just mocking me about the vortex tube... 😂😂😂
roon
135
Post by roon » Tue Jan 16, 2018 9:13 pm
Tommy Cookers wrote:
Tue Jan 16, 2018 1:15 pm
...hairpin valve springs were used in some aircraft aircraft and motorcycle engines...
