2018 Scuderia Toro Rosso F1 Team - Honda
HPD
198
Re: 2018 Scuderia Toro Rosso F1 Team - Honda
Basically, they got permission. But then they told him to cancel the modification. This without a document signed by the FIA.
This is crazy.
Jolle
Jolle
132
bigblue wrote:
08 Oct 2018, 10:19
Eryngii wrote:
08 Oct 2018, 02:22
This Japanese article has details.
http://www.topnews.jp/2018/10/07/news/f1/174666.html
Thanks. Sounds like a complete mess from the FIA. Imagine if it had happened to Hamilton or Vettel, there would have been uproar.
Well, you are allowed to change parts for the same spec. There was a lot of uproar in 2014 when Hamilton changed is brakes from AP to Brembo (I think) between Q and race. If they wanted to change the PU with one of the same spec, no troubles. This prevents to have a Q engine and a R engine and swap them every time you feel fit.
nzjrs
60
Jolle wrote:
08 Oct 2018, 12:56
bigblue wrote:
08 Oct 2018, 10:19
Eryngii wrote:
08 Oct 2018, 02:22
I think you've almost got it. I imagine the FIA said yes, and then someone whispered in their air that this decision 'could be argued to set a precedent allowing PU software/settings/mapping changes to be made in Parc Ferme'
We are well into the era where mapping 'its only software the engine is the same' changes are in the order of 1/10th per lap. I reluctantly agree they shouldn't be allowing these sort of changes.
HPD
198
nzjrs wrote:
08 Oct 2018, 13:14
Jolle wrote:
08 Oct 2018, 12:56
bigblue wrote:
08 Oct 2018, 10:19
It is assumed that Honda request was for reliability, not for advantage. In the end, they decided to run without using all the strength of the PU.
But Tanabe made it clear that this was not going to change the final result. No matter how strong your engine is, if you do not take care of your tires it does not help.
Jaisonas
Jaisonas
So we can assume that they will run the engine full power in CotA?
rogazilla
rogazilla
possibly but it was also mentioned Honda may run experiments with the rest of the seasons.
Sieper
73
Not yet, but it will run fuller power yes, especially so in the case of Gasly but also for Hartley. I am again anxiously looking forward to the COTA weekend.
Sieper wrote:
09 Oct 2018, 16:09
Why are you looking again anxiously forward to the COTA weekend @Sieper?
Sieper
73
anxiously just means (in this context) I can't wait for it to start! Not I am fearsome :-D. I am really looking forward to it and expect good things to happen for STR.
Sieper wrote:
09 Oct 2018, 16:52
Oh okay, I thought you were afraid of bad results. :lol: I am also very curious how it will go.
Sieper
73
If the aero update works as well as the engine it might even be a very big surprise.
Sieper wrote:
09 Oct 2018, 17:36
I agree.
McMika98
McMika98
-24
Yes hoping for a good update and then a possible podium in Mexico.
!Technical
!Technical
I expect stellar quali performances and rubbish Sundays due to strategic blunders.
rogazilla
rogazilla
I just hope the Aero works and we see some pace in the car.
