Opinions of pit stop car lifter favourite
Which pit stop car lifter do you like the most?
Conventional manual front jackboard and rear jack lifter stick in F1
16
80%
State-of-the-art airjack hose nozzle that used in IndyCar, DTM and others
20%
Total votes: 20
theriusDR3
theriusDR3
F1 pit front jackboard
F1 pit rear jack lifter stick
Pit stop airjack hose nozzle in other auto racing categories
I would go to state-of-the-art airjack hose nozzle because state-of-the-art airjack hose nozzle is more technological than conventional manual front jackboard and rear jack lifter stick in F1.
How about yours?
jjn9128
769
Re: Opinions of pit stop car lifter favourite
Air jack is heavy component to have onboard. It's only used as a necessity of minimum pit crew in pits. Wouldn't necessarily call it state of the art.
#aerogandalf
F1 Cars are too heavy even without air jacks imho.
Jolle
Jolle
132
Air jack systems are only used by (semi) spec series because the weight penalty is the same for everybody. It’s a cost saving method (you need a few less people working on the car).
F1 uses the traditional lifters because it’s faster. So I go for what they use now.
theriusDR3
theriusDR3
Jolle wrote:
04 May 2020, 10:29
Not only F1, F2 also use the same conventional jack lifters.
Jolle
Jolle
132
theriusDR3 wrote:
04 May 2020, 11:34
Jolle wrote:
04 May 2020, 10:29
https://theodoreracing.com/wp-content/g ... RAIN-9.jpg
That’s why I said only... not always ;-)
adrianjordan
Why fix something that isn't broke?
Favourite team: McLaren
Zynerji
110
adrianjordan wrote:
04 May 2020, 13:46
Sub-2.5 second pitstop with the current setup tells the tale. The Jacks currently in F1 are great.
Now, having a standardized jack, with a variable lifting plate for different wing/crash structures could be a great cost savings mechanism...
3jawchuck
3jawchuck
37
The video posted here: viewtopic.php?p=899792#p899792 seems to fit quite well in this topic.
Big Tea
As all cars must have a flat 'plank' underneath, why not a drive - on air powered platform? No weight on the car and no jack man to run down
Big Tea wrote:
04 May 2020, 15:40
There'll have to be a delay for the car to be stopped before it can be raised, else you'll unnecessarily wear the plank. Much less so with the jacks.
Zynerji
110
Big Tea wrote:
04 May 2020, 15:40
Positioning. I imagine the damage to the floor could be catastrophic if it isn't very close to perfect. Also, with <6mm clearance at the tea tray, it would need to be built into the pit lane to be flush. It's not something that could just be bolted to the pit box, and taken to the next race.
Jolle
Jolle
132
There is very little time to be gained. The wheel guns already do their magic while the car is rolling, car is up in the air before the tires are ready to come off. So the moment is then the car is dropped and then only at the front. So maybe a tenth of a second.
Looks like a solution searching for a problem. The current system works as well as is required and any replacement is unlikely to result in a shorter race-elapsed time. Ergo, it's pointless to waste resources on it. A bit like this thread, really... :wink: :lol:
gridwalker
gridwalker
Indycar have been using built-in air jacks for over 30 years. There is a case to be made that the F1 systems (including the lighting gantries and push-button feedback from wheel mechanics) are actually more advanced.
