McLaren F1 successor
e36jon
e36jon
Re: McLaren F1 successor
Holm86 wrote:
Fri Aug 07, 2020 4:05 pm
sosic2121 wrote:
Fri Aug 07, 2020 12:08 pm
Holm86 wrote:
Wed Aug 05, 2020 11:55 pm
Does anybody know about the inclined axis valves he is talking about?? What's the concept around that??
Could it be that normally (intake) valve stems are parallel, but not in this engine?
I don't know, it's the first time I hear the terminology of inclined axis valves
Greetings all
I didn't listen/see/read the original reference that started this conversation. I believe the concept under discussion is usually called 'radial valves'. If you Google that term you'll find lots of explanations with illustrations, descriptions of benefits, etc.
Cheers,
Jon
sosic2121
sosic2121
19
e36jon wrote:
Fri Aug 07, 2020 6:01 pm
Greetings all
Cheers,
Jon
Thank you for the information.
So, my assumption was wrong.
Gordon Murray said the engine has inclined axis valves. We are trying to figure out what that means. Any guess?
Road & Track wrote:Freed from road-car emissions and noise constraints, the T.50's Cosworth V-12 gets new heads and camshafts, a higher compression ratio, a less restrictive exhaust system, and a higher RAM air intake to make 720 horsepower. Redline is set at 12,100 rpm, and the T.50S ditches the road car's six-speed manual for a paddle-shift XTrac Instantaneous Gearchange System (IGS). The IGS is a single-clutch pre-selector six-speed, which has the next gear ready as soon as you pull the paddle, so you get dual-clutch speed without the weight. Murray says the weight difference between the manual and the IGS is negligible. GMA says the S weighs just 1962 pounds (890 kg), thanks largely to a much pared-back interior and thinner body panels.
One figure is up, though—downforce. GMA added a new front splitter, dive planes, a central fin, and a delta-shaped rear wing, which looks similar to the front-wing on Murray's championship-winning Brabham BT52. With the rear-mounted fan spinning at 7000 rpm, the T.50S will generate 3307 pounds of downforce. And it's capable of more.
"We actually got up to 4189 pounds in CFD, but with the wheel and tire envelope we have on the car, we couldn't support that. So we decided to back it down to 3307 pounds," Murray says.
Source
humble sabot
26
think Honda RVFC but with two cams in the usual place.
I was trying to find an example of it used in an car engine but the one I see in my head isn't tied to any names.
Essentially though, the benefit is that you naturally build a more three dimensional dome out of the angles between the valve faces, rather than the pent roof usually forced by parallel valves. It makes for a really neat looking surface on the camshaft since it's not perpendicular with the rotating axis.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
Mchamilton
Mchamilton
Morteza wrote:
Thu Sep 03, 2020 5:02 pm
https://twitter.com/PlanetGMA/status/13 ... 7575987200
Source
sounds like a similar box to an Aventador, which is practice is actually pretty shocking
humble sabot
26
Dario Franchitti's accent is doing my head in. Scottish? Italian? Is that what happens to your voice when you live an anglo life in Monaco after retiring from F1? I don't even dislike it, but it's breaking my brain.
the GMA V12 sounds ok at pre break in revs, definitely rev happy.
Amazing that such a tiny NA motor is eating up so much space inside an Ultima with all that airbox and the radiator over the gearbox.
static balance
dynamic balance
static imbalance
dynamic imbalance
jjn9128
392
humble sabot wrote:
Sat Oct 17, 2020 7:52 am
Really?? Sounds all Scottish to me.
Road & Track wrote:. With the rear-mounted fan spinning at 7000 rpm, the T.50S will generate 3307 pounds of downforce. And it's capable of more.
Source
Pounds???? At what speed???
#aerogandalf
Andres125sx
356
jjn9128 wrote:
Sat Oct 17, 2020 9:31 am
Source
From still? =P~
jjn9128
392
Andres125sx wrote:
Sat Oct 17, 2020 10:38 am
From still? =P~
It doesn't full on seal to the floor, the fans suck off the boundary layer to keep air attached in the over-expanded diffuser.
#aerogandalf
Ringleheim
Ringleheim
There are many excellent videos on Youtube of various people interviewing Gordon Murray about this car, and talking in detail about its design and evolution.
There's a great one from Harry of Harry's Garage fame, also one from Chris Harris, and many more.
Check them out if you are interested in this car!
Pat Pending
Pat Pending
Ringleheim wrote:
Sat Oct 17, 2020 2:30 pm
That must have been a mind numbing day for Gordon - back-to-back interviews with each journo asking basically the same questions! :lol:
Ringleheim
Ringleheim
Pat Pending wrote:
Wed Oct 21, 2020 12:38 pm
No, not like that at all. These are on different occasions and the "interview" amounts to a detailed conversation about Murray's past, his engineering philosophy, specifics on the car itself, etc. The car is sitting there as a prop for most of the conversations.
There's really good stuff out there.
I'm not a fan of the appearance of the car...I wish he had farmed out exterior design to experts, but overall it's a fascinating project. I don't like the fan at the back either, but that is kind of a Murray TM at this point.
Still an awesome car all the way around.
humble sabot
26
Ringleheim wrote:
Wed Oct 21, 2020 9:24 pm
Pat Pending wrote: That must have been a mind numbing day for Gordon - back-to-back interviews with each journo asking basically the same questions! :lol:
OH no! Definitely like that! I watched all of them, hoping for new questions, but it was the same thing over and over and over and over again. And they were all clearly shot within a very short span of time. And Gordon's answers were almost precisely the same everytime.
static balance
dynamic balance
static imbalance
dynamic imbalance
