[KVRC] Khamsin Virtual Racecar Challenge 2016
LVDH
49
Re: Khamsin Virtual Racecar Challenge 2016
Yes, the car looks fantastic.
Ft5fTL
Mantium Challenge - Pure Power Racing
Alonso Fan
That looks awesome. Is that the 'PPR Technology Centre'?
Jokes aside, it's a beautiful render. Water could be a little less 'blue' but that can be overlooked
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
machin
162
Presumably the "blue" is a result of the colour that the inside of the pool is painted, as opposed to any sort of reflection of the sky...? So it could realistically be yellow, purple or any other colour the owner wanted? ;-)
Anyway... a little render of the CCE LMP01 in round 1 configuration (actually, it has the "old" engine intakes... so its not quite "right")...
Alonso Fan
On second thoughts, machin is correct.
SHR Modding
Youtube
Twitter
Discord
julien.decharentenay
CAEdevice wrote:The limit I have is that I am not able to extract the pressure differential and to write it in a log (as it happens with the areo forces).
Sorry about not having taken up on your earlier query on this. To extract the pressure differential, please do the following:
- Start ParaView;
- Open the openFoam file;
- Only select the boundary condition (in the part option) that you want to calculate the surface integral of pressure on;
- Apply a calculator filter;
- Set a new field "Pressure = 1.2 * p" (the pressure calculated and output by openFoam is normalised by the density);
- Apply the Surface Integral Filter;
- the surface integral of pressure is reported under Pressure.
Change the selected boundary condition to extract the value at the other surface.
CAEdevice wrote:Another issues for a beginner is the manage the double start (preliminary run). What about starting directly from the second stage?
You can, but it just takes longer to establish, hence more iterations...
CAEdevice wrote:\Would it be possible to submit larger files or step format? It would help the legality check and the pre processing too.
Please send the STEP format. I am sure that Chris will appreciate having something easier to handle. On the downside, this removes the control of the STL export from you.
The new KVRC background.... Great rendering! Very impressive.
CAEdevice
51
Thank you!!!
Yes, the preliminary run saves some time, but I would need the list of the commands /procedures to run.
RicME85
52
Have submitted by car for the first race. Decided to go with the intro class and battle it out with Machin 8)
machin
162
RicME85 wrote:Have submitted by car for the first race. Decided to go with the intro class and battle it out with Machin 8)
http://s32.postimg.org/hogzmi805/car.jpg
http://s32.postimg.org/cao6etmh1/car.jpg
Awesome! Bring it on!
graham.reeds
graham.reeds
16
I am not going to get my car done in time. :-(
I've barely drawn the side view and not even touched the rear wing yet. I only just finished the comprehensive article on end plates just now.
I will crack on tomorrow but I will doubt I will have it finished.
CAEdevice
51
My car is almost complete: I have already submitted it, but I hope to obtain some other front downforce in the next hours.
Ft5fTL
Alonso Fan wrote:That looks awesome. Is that the 'PPR Technology Centre'?
Its my private mansion :lol: The source of the water color is as machin said the color of the pool.
:o Thanks .
cdsavage
cdsavage
19
There's a bit over 24 hours until the submission portal for round 1 closes. So far we have entries from:
- CAEdevice
- Competition Car Engineering
- HP Racing
- Kineuton
- Machin's Shiny Melon
- MantiumRAY
- MercuryMotorsport
- Pure Power Racing
- sjns-Racing
- TalnoRacing
