![Idea :idea:](./images/smilies/icon_idea.gif)
could be the opposite maybe;avatar wrote:This is how Sauber have used the blown wing in the past (to prevent airflow separation from the wing) - lets them run a steeper wing angle, thus more downforce.Asphalt_World wrote: Therefore, turn this situation upside down and a car going slow round corners would not create much down force because the airspeed over the wing is slower. Allowing extra air to pass through the middle of the wing or behind it in some other way would reduce 'stall' and make the wing more efficient, thus pushing the car down on the ground more.
So, Macca run a setup with less wing giving them a straight line speed advantage but due to this anti stall system create as much down force as a higher wing setting on a normal rear wing system.
But the theory (as I understand it) is that McLaren have found an additional effect; by overloading the blowing of the wing, causing the airflow to separate & reducing drag - thus more straight line speed.
The only way a wing loses load is if a big hole is shot through it to disrupt the suction, or if pressure is taken off of it.Speaking to Gazzetta dello Sport, Newey said: "McLaren's F-duct is intelligent and opens new ways. However I'm worried about the safety aspect. The system works by stalling the rear wing and getting rid of the load. To force a driver to make a sudden movement to change normal load conditions has to do with safety."
I would go the other way and have a default low angled stalled wing and blow on corner entry to increase DF.wesley123 wrote:well, there is a simple problem with it, you cant go to incredibly low AoA's as then there is no way of ducting it, i dont know how they will do it in monza
F1SA.com wrote:Mercedes debuted a McLaren like F-duct system on Michael Schumacher's car on Friday morning in China.
Team reserve driver Nick Heidfeld said a decision has not been taken about whether the device, activated in the cockpit by the driver and designed to spoil the downforce to the rear wing on straights, will stay on the W01 for qualifying and the race.
"It is now being analysed to see whether we use it on both cars for the rest of the weekend," Heidfeld told the German broadcaster Sky.
The 32-year-old said he thinks the system works well, after the wind tunnel data looked "promising".
Meanwhile, unlike the side pod mounted inlet on the Sauber, and McLaren's on the upper monocoque, Ferrari's new aero vent system lets air in via the actual engine cover itself.
Following his engine failure on Friday morning, Spaniard Fernando Alonso returned to the Shanghai track for the afternoon session with the V8 he used to win in Bahrain last month.
At Monza a low angled smaller wing is needed to decrease drag on the long straits.raymondu999 wrote:The blowing would *decrease* DF though. You would set a higher AoA and blow it for the straights, then stop blowing in teh corners for more DF. And I see what wesley means. The duct in itself wouldn't fit.
