Alternative engine configuration
FW17
185
Re: Alternative engine configuration
FoxHound wrote:
WilliamsF1 wrote:
FoxHound wrote: quit, or quit moaning about it.
Why should this be when it is not your fault?
Read the sentence in it's entirety.
The issue is, if something you run on your car isn't good enough, find someone who can do it better, quit, or quit moaning about it.
If you cannot do any of the above, it is your fault.
Why should Red Bull be blamed for failing to get an new engine manufacturer to enter the sport when the engine rules are locked down (and have a 5 year development lead) by Renault and Mercedes who demanded that there new rules be implemented or they would leave the sport?
You are just bitter that Red Bull bitched about Renault and they should face the consequence for the same.
FoxHound
55
WilliamsF1 wrote:Why should Red Bull be blamed for failing to get an new engine manufacturer to enter the sport when the engine rules are locked down (and have a 5 year development lead) by Renault and Mercedes who demanded that there new rules be implemented or they would leave the sport?
Well, Williams...let me just say that Renault and Mercedes were keen for either 4 cylinder or V6 engines. Mercedes would've stayed with V8 as it fits the V8 AMG demographic. But it needed to have energy recuperation which was/is a massive issue of our time. Let me remind you 4 cylinders were even benched at Brixworth before Audi/VW turned their noses up at F1(again).
But if you are advocating the use of a V8 that's frozen for the last 6 years as progress, then I'll leave you to it.
Besides, Why should Red Bull not consider getting a different supplier like Cosworth, Ilmor or AER? Those avenues are available, and Red Bull are making money out of the sport. So what's the problem?
Time? It took Mercedes ages to get aerodynamically competent.
Money? They spend a good 100 million net less a year now than they did in 2009.
WilliamsF1 wrote:You are just bitter that Red Bull bitched about Renault and they should face the consequence for the same.
Bitter? why the personal rubbish?
I love the sport, I'm passionate about it. And in light of their 8 titles, when a team that hasn't built an engine bitches about an engine, it's staff, and it's competence, freely, I find that crass, uncouth and bitter.
JET set
NL_Fer
NL_Fer
82
What is not to understand on Bernies point of view. He is as clear as one can be about it. He said, back in the old days, you and me could built a good car, buy an engine and race to win. Simple.
Now the manufacturers with a winning engine, will not supply a team, if it has a good chassis, which can beat them.
And for Redbull to built an engine. They are no car manufacturer. There is no return on investment for them, if they throw 300M on an engine.
FoxHound
55
NL_Fer wrote:What is not to understand on Bernies point of view. He is as clear as one can be about it. He said, back in the old days, you and me could built a good car, buy an engine and race to win. Simple.
Why not, I mean let's give them a better engine than their competitors, because there is "no return on the investment" for Red Bull.
How about we swap that around and force Red Bull to supply current and up to date Chassis and Aero for teams that find "no return on the investment" for their operations.
Failing that, we could just give other teams different rules which favour them over Red Bull.
Trample over every sporting code in the process, because yanno..."no return on investment" right?
Good job Usain Bolt or any of their sprint team aren't gas powered...
Back on earth...
It's not down to the suppliers to find teams, that needs to be made clear.
If a team has a supplier, and jumps prematurely without a fallback option, that team is at fault.
Not the sport, not the competition, not other suppliers, and not it's supplier.
JET set
I don't know how this could have worked ...If the PU weight regulation aren't the same then the lighter PU has an edge in quali. If they are the same then the v8 has a disadvantage at the beginning of a race as the V6 is lighter cause it carrying less fuel. Not to mention the complication is will cause Pirelli cause of the different power curves. You also have to stop calling it Formula 1.
532
FoxHound wrote:That 860 figure is all the time in the alternative engine as there is no energy recovery(KERS).
Therefore it has the advantage when the other PU's are out of battery energy, and it runs the advantage of not having to run batteries and the ancillaries associated with energy recovery(lower CoG + better aerodynamic possibilites).
There will be big advantages aerodynamically, and with minimum car weights allowing them to use ballast strategically from race to race(better tyre management)
Basically, even if that engine is limited to Renault's level, the payoff will be huge advantages in chassis and aerodynamics.
Simply, it's a different engine specification that operates under different rules and way more than just engine advantages.
The other advantages for the alternate engine are:
No fuel flow regulation - can run as rich as they want
No race fuel limitation - no fuel saving required. The hybrids will, presumably, still be stuck on 100kg per race and will have to fuel save at certain races.
Free placement of exhausts. Hello EBD. It's like another aero regulation too.
FoxHound
55
wuzak wrote:The other advantages for the alternate engine are:
You can keep going...
I'm not sure they do get free placement of exhausts however. But if they do, allied to this idiotic alternative engine plan, F1 will likely be dead to me unless Manufacturers can produce their own engines to those exact same rules.
It'd be like getting 15 average rugby players to play Aussie rules against Barcelona's 11 man football team. With Barca blindfolded. In wheelchairs. Sedated. All within the rules.
JET set
djos
130
FoxHound wrote:I'm sorry turbo,
But if Red Bull hold a gun to the head of the governing body, utilising a quit threat as ammunition when it runs 2 teams, is ample evidence that this was driven by Red Bull.
This was exactly what Red Bull wanted, to stay in the sport. They have said as much too, so there can be no argument what the prime motivator was.
If the FIA didn't blink, anything was possible.
Red Bull used the situation at large, and the fact they have 20% of the grid, to their advantage.
Defending Red Bull to say that any team would've done this plain wrong. This is unprecedented....
So it's not ok for RedBull to threaten to quit over engine rules but it is ok for Mercedes and Renault to threaten to quit to get their way which created this mess in the first place?
Make up your mind mate!
"In downforce we trust"
FoxHound
55
Find the quotes, where both Renault and Mercedes threatened to quit please.
And then put the context into it. Frozen engines for 5 years.
What reason does any manufacturer have to stay or enter under such conditions.
This is in no way the same as having an engine, then threatening to quit because your supplier isn't performing.
To put it starkly, imagine aero was frozen, with teams behind allowed to catch up until "equalisation" was achieved... then allowed to continue for 5 years.
Red Bull would've left already...
JET set
djos
130
FoxHound wrote:Find the quotes, where both Renault and Mercedes threatened to quit please.
Here's a Renault article, I'll dig a couple more later: (i know they exist because I've posted them on f1t before)
http://www.motorsportmagazine.com/f1/f1 ... -rages-on/
Renault is threatening to pull out of Formula 1 if the much-discussed new 1.6-litre, four-cylinder turbo engine formula for 2013 is not soon confirmed by the FIA. Many people in F1 believe the new formula will be put off for a year or two, and some hope the FIA will relent and opt instead for a turbo V6. Following more than a year’s discussions with the teams and engine suppliers, the FIA is expected to make a decision on delaying the new formula by the end of the month.
Renault is the only enthusiastic supporter of the tiny turbo concept, which has failed to attract interest from new manufacturers. Both Ferrari and Mercedes-Benz prefer V8s or at least V6s, and everyone is worried about the costs of building and developing new engines. Still, FIA president Jean Todt is a big proponent of the small-capacity turbo and with Renault’s strong support he may insist on that formula. McLaren team principal Martin Whitmarsh has been deeply involved in formal talks about the new formula and discussed the matter in Montréal.
djos
130
And one more for now:
http://m.autosport.com/news/report.php/id/113363
The switch to the new turbo engines for 2014 was essential to prevent Mercedes from thinking about quitting Formula 1, a senior board member from the German car manufacturer has revealed.
It is already widely known that Renault would have left F1 if the V8 engines had stayed, while Honda would not be coming back in 2015 if the regulations had not changed either.
But now Thomas Weber, the Daimler board of management member who is head of R&D, has made it clear that the German car manufacturer's commitment to F1 would also have been in doubt if things had not changed.
FoxHound
55
"Commitment is in doubt" = flagrant quit threat?
:lol:
Your first article also clearly states Mercedes and Ferrari were happy to keep V8's on proviso of there being development.
Also, I see no quotes from Renault personnel.
JET set
djos
130
FoxHound wrote:"Commitment is in doubt" = flagrant quit threat?
:lol:
I'm on my phone atm, I'll find some better links later.
Btw fox, you're a smart fellow, you should be able to recognise a vailed threat in Corp speak surely?
djos
130
FoxHound wrote:"
Correct, neither wanted a 4cyl turbo, however both where happy to downsize as long as it was a v6 turbo:
http://www.jamesallenonf1.com/2011/06/f ... n-the-air/
It was widely reported by many many sources and confirmed by Jean Todt:
http://www.formula1nexus.com/renault-th ... d-in-2013/
Now it’s come out, however, that the idea for the smaller powerplants was originally proposed by one of the major manufacturers, i.e. Renault. “It was them who proposed the rules that the FIA accepted,” FIA president Jean Todt recently told Spanish newspaper Diario Sport. “The proposal didn’t fall out of the sky, but instead we had 11 meetings with all the representatives from the engine makers involved.”
Now Renault, getting wind of the FIA’s about-face on their about-face, are threatening to quit if the new tech regs aren’t adopted. If I talk to Renault,” said Todt, “they say that if we don’t introduce this engine for 2013 they will leave F1; if I talk to Mercedes and Ferrari, they ask me to delay the introduction for a few years. They aren’t against the rules, they just wanted them postponed.”
But also this from Renault confirming it:
http://www.jamesallenonf1.com/2011/11/t ... ing-in-f1/
Caubet also confirms that Renault threatened to pull out of F1 altogether if the new generation 2014 engine wasn’t introduced, “We pushed the FIA to conclude on new regulation – concluded in June. Either the new regulation is clear and we will stay in F1 or we keep the same engine and Renault will stop,” he said.
“We took the decision to stay in F1 only if the new engine was relevant and the new regulation was relevant.
 We now start the race with 170kg of fuel. In 2014 we will start the race with 130kg – nearly 35% less. Each year we are pushing to decrease the fuel consumption by 5%. It’s difficult to reach this goal.
Btw, this final quote from Caubet was very prophetic!
“Today the engine is more of a commodity; in three years, it will be the key thing that makes you win or lose the race.”
Phil
66
turbof1 wrote:@Phil: what you are telling is that if Renault, Mercedes, Honda and Ferrari end up being slower then the alternative engine, is that they have to dump their high cost PUs to run an engine which cannot be produced by their own or rebranded. They are not going to do that. Rather they will leave the sport in that situation. They are in this to get brand exposure as engine manufacturers, to show how high techy techy they are. Running an engine that is not theirs is taking all of that exposure away, along with the incentive to stay in F1. Yes, even in the cases of Renault and Honda, who have not invested dozens of millions into highly regulated PUs, just to be beaten by an engine free from many restrictions.
I'm not saying what they will or won't do; I'm saying what they can do. I really don't see it as a big issue. The big F1 teams are in F1 for promotional reasons, for exposure, image, prestige etc. It's a big marketing exercise. Not because they can prove that they can build engines. If the 'winning formula' is using an alternative engine by a supplier that is cheaper and off-the-shelve, it's not all bad. The important point is winning with a car that has your name attached to it. People don't buy cars because of the engine inside; they buy it for all sorts of reasons, namely brand name, maybe prestige and the sum of all pieces that either makes the package attractive or not. When we had engine freezes it didn't stop teams from being in F1, so it's daft to suggest that if the sport moves to include alternative engines not bound by the same rules that end up being better to win, that everyone would just pick up and leave (especially if they could use those very engines and slash a huge sum off their R&D and engine development program).
Yes, the current dominator - Mercedes - might not be happy, but at least 2 from those 4 engine makers are not winning and are far away from even being close to. They'd trade an alternative engine that's capable of winning and increasing their success with their own not working engines in a heartbeat. Look at Renault; They're in such a crisis, we're still not sure yet if they'll be around next year. Because the exposure they are getting with the engine is namely negative and the money they are investing isn't paying off. It's not helping them better their image nor is it helping them sell more cars. And at this point, it's not a given that the money they are going to have to invest will yield any reward, or indeed if they can close that gap - if its in their ability to. Honda might find themselves in a similar spot if 2016 turns out the same as 2015. Ferrari is a toss up; They've been in F1 long enough to understand why they are in here and it certainly hasn't got anything to do with hybrid engines they're not using to promote their sports-cars anyway. And even if they are like Mercedes do, people are not actually stupid enough to think they are buying Mercedes A class with actual F1 engines in there.
What it effectively boils down to is that the sport is in a mess. We either have a sport that demands that you need to build your own engines to either have one and be competitive (which is clearly no given, seeing that from 4 engine makers, only 1 is capable of winning on a regular basis, another is close and the leftovers are far far away from that) and if you can't, well, then you're just there to fill the grid. Or we have alternative engines that are not bound by the same rules and thus might end up being better and that will give a viable alternative to most teams that is cheaper and performs better, but at the risk that it might upset the engine manufacturers. Either way, you're going to mess with someones interests.
Or, the engine manufacturers come to their senses and realize this can all go away by folding, enabling a selling-price-cap that is better affordable and not go the way of wanting A and B spec engines that will artificially give them control over how competitive their customer is.
The biggest problem is that we have a situation where a team might end up without an engine. That IMO is the biggest problem of all; it might be wrong to force a supplier to supply a team, but it's equally wrong to have a team unwilling to find an engine of choice. It is essentially because the engine suppliers are their own teams and because of that, supplying will have a certain conflict of interest. It's neither the fault of the suppliers nor the customers, but it's something the sport needs to address. The alternative engine just might do this (not without tears, but sometimes one has to chose the lesser of two evils).
#Team44 supporter
