2021 Emilia Romagna Grand Prix - Imola, Apr 16 - 18
Hoffman900
Hoffman900
242
Re: 2021 Emilia Romagna Grand Prix - Imola, Apr 16 - 18
Lewis I think was tasing blood in the water and got too impatient. He probably knew he was screwed as soon as he moved the wheel to get around George, he was just a sitting duck from there on out. Lewis pretty much admitted he made a rare mistake in terms of being impatient.
I don't know why fans argue points of view, which sometimes contradict what was said, more passionately than the drivers themselves.
dans79
267
basti313 wrote:
21 Apr 2021, 15:19
If I am not mistaken, Russel was on the absolute edge of the track. No idea how you can give more room there on the outside.
Furthermore the position of Russel did not play a big role, it was simply too wet on the inside. You can see that Ham simply slides across the corner due to the wet tires.
There is only one solution...wait for the straight. Any move to the wet side in this corner would have ended with one or two cars in the gravel. If Rus would have done the stunt to go on the wet side, the most probable outcome is sliding into Lewis.
Considering the big blue flashing lights, and how close to George Lewis was well before the braking zone, George should have been off the racing line, and traveling at a reduced speed just like the other cars behind him where.
Instead he was to focused on passing bottas because of needing to prove a point, or brain fade.
202 105 104 9 9 7
SiLo
144
Getting sucked into another Max vs Lewis fan rivalry discussion it seems... Both camps should be pretty happy right now, we have a real fight on our hands to enjoy!
@nathan - I think reverse gears have always been required by the FIA?
Felipe Baby!
Jolle
Jolle
133
dans79 wrote:
21 Apr 2021, 15:39
basti313 wrote:
21 Apr 2021, 15:19
https://ibb.co/v4SK2pb
On a damp track with only tramrails to drive, you can’t get off line to let someone pass. You do that on a straight. If Russell gave Hamilton on that part, he would have gone off the same way Hamilton himself did (and Alonso a few corners later avoiding the rubble).
The reason Verstappen lost so much time passing this group because he was careful and took no risks. Hamilton did, and if it worked out, a smart move to gain time. But it didn’t.
dans79
267
Jolle wrote:
21 Apr 2021, 15:46
This is previous corner, more than close enough to know he needed to get out of the way (on the strait between the corners).
202 105 104 9 9 7
Phil
66
Jolle wrote:
21 Apr 2021, 15:46
AFAIK, the rules are pretty clear that if a blue flag is waved, the driver being shown the blue flag must yield and make room. That includes lifting, braking, getting out of the way etc.
If there is a dry line, then that responsibility goes to the driver who is required to take action (aka the driver being lapped). It's certainly not within the rules to wait for the next straight or something.
Straight or corner, I would expect a driver to make it easiest to being lapped by taking appropriate action immediately. It just so often happens that mostly it isn't done this way and the stewards are rather lenient in applying warnings and penalties (not always though!).
#Team44 supporter
e30ernest
e30ernest
27
dans79 wrote:
21 Apr 2021, 15:59
Jolle wrote:
21 Apr 2021, 15:46
https://ibb.co/9ZFCg96
Yeah pretty much this. Russell could have given way before the braking zone, but he would have lost out to the cars in front of him. This is why I don't blame him at all. Lewis on the other hand should have been more cautious.
MKlaus
MKlaus
e30ernest wrote:
21 Apr 2021, 16:03
dans79 wrote:
21 Apr 2021, 15:59
Jolle wrote:
21 Apr 2021, 15:46
absolutely. lewis agreed that he was somewhat restless in that chase and could have done better.
MKlaus wrote:
21 Apr 2021, 16:16
Yes, as usual, he put his hand up and admitted making a mistake. Didn't try to blame anyone else.
Jolle
Jolle
133
Phil wrote:
21 Apr 2021, 16:01
Jolle wrote:
21 Apr 2021, 15:46
You have to give way within three marshal posts (who wave blue flags), not immediately. Although the front runners like it to be.
At the moment Hamilton slid off, Russell was still in his right taking the racing line, Hamilton didn't wait after tamburello where Russell was obliged to yield, but took a risk with an overtaking manoeuvre. Not Russell's fault.
MKlaus
MKlaus
Just_a_fan wrote:
21 Apr 2021, 16:27
MKlaus wrote:
21 Apr 2021, 16:16
experience is the biggest teacher. :)
dans79
267
Jolle wrote:
21 Apr 2021, 16:28
Based on several of the onboards, marshalls weren't waving flags for Max or Lewis, they seemed to be 100% relying on the light boards.
202 105 104 9 9 7
Jolle
Jolle
133
dans79 wrote:
21 Apr 2021, 16:48
Jolle wrote:
21 Apr 2021, 16:28
I've watched the onboard from both Hamilton and Russell a few times now, Russell moves to the outside of the track, opening up the inside and takes a wider line in approach to the corner to make room for Hamilton to take the apex.
dans79
267
Jolle wrote:
21 Apr 2021, 17:00
dans79 wrote:
21 Apr 2021, 16:48
Jolle wrote:
21 Apr 2021, 16:28
I'm aware, that's his way of doing what he is required to do (let Lewis by), and loose the minimal amount of time to Bottas. Lewis should have just tucked in behind him and then complained on the radio.
202 105 104 9 9 7
El Scorchio
Hamilton made a mistake. They all do. Most of them did in this race alone. Some got luckier than others with the consequences of their mistakes.
In a future race it'll be another driver other than Hamilton who makes a mistake. Swings and roundabouts. Not one single driver on the grid is exempt from making silly mistakes. The only difference is how people on here will look to try and make excuses for them or explain them away.
