McLaren MCL33
asendra
asendra
Re: McLaren MCL33
Morteza wrote:
11 May 2018, 12:12
All three ducts are divided by the looks of it?
https://pbs.twimg.com/media/Dc6IfMPWkAA5n60.jpg
I tried a quick exposure correction from my iPad.
Re: McLaren MCL33
cramr wrote:
11 May 2018, 07:56
godlameroso wrote:
10 May 2018, 22:17
Vanja #66 wrote:
10 May 2018, 22:12
You mean all the way trough the car?
Yes duct the air coming through the nose and speed it up so that it exits as a jet near the diffuser, maybe to add energy to any vortecies interacting with the rear wheel to limit it's effect on squirt. Or maybe to help with places that are prone to flow separation.
https://arc.aiaa.org/doi/10.2514/1.8552
If I'm not wrong that's not really possible since it's not allowed to have any air duct passing through the cockpit (to avoid possible F-duct and things like that in the past). Besides that it would be hard to keep enough momentum in that flow to "survive" in good condition an almost 6 meters trip. You are probably better off getting a good cokeline flow that bringing it from the front of the car
I mean if the front wing can manage airflow over 6 meters, and given the high pressure in the sidepod, one would think it would be easy to channel airflow through the car, there's a huge pressure differential between ambient air and air traveling through the car being heated by the heat exchangers and engine components. Heating air mass causes it's volume to increase, there is your pump. Along with airflow travelling at 100+kph.
There's enough air pressure travelling through the car to do this
Big Tea
99
Re: McLaren MCL33
godlameroso wrote:
11 May 2018, 18:12
cramr wrote:
11 May 2018, 07:56
godlameroso wrote:
10 May 2018, 22:17
Could it be ducted to help with their cooling problem? possibly having a secondary role as well?
Re: McLaren MCL33
godlameroso wrote:
11 May 2018, 18:12
http://cf.c.ooyala.com/AzcTF5dDrz7qzJyu ... o255356994
There is, but that's mainly because there's a load of low pressure on top of the sidepod, and a lot of expansion to slow air down into the sidepod to built pressure - there isn't room to do that with a duct from the front there.
As an aside, it looked like Stoffels car had some new internal covers in the area over the exhaust on the garage shots from FP2 - does anyone have any good photo's so we can check?
240
Re: McLaren MCL33
Scarbs is closer to the truth.
The side inlets dont merge with the centre one though. I beleive the converge underneath the centre tunnel and possibly blow through the nose to the S duct.
Jackles-UK
Re: McLaren MCL33
A theory about the lack of S-Duct: If I am right in thinking that an S-Duct is designed to keep the flow of air over the nose attached then it makes sense to ditch it with the new nose philosophy.
They appear to now actively want the air to spill off either side of the front part of the nose, get cleaned up by the side vanes on the edges of the nose and then feed the cape and new chassis turning vanes.
Re: McLaren MCL33
f1rules wrote:
11 May 2018, 12:15
i think the two outer push air below you can easily see they are angled down inside, the central im not sure, but im quessing above
The down angle is because the supports of the pylons are there and need to be strong.
Re: McLaren MCL33
Re: McLaren MCL33
Via AMuS
ALO_Power
ALO_Power
Re: McLaren MCL33
Baku vs Barcelona
Well, I don't see any difference on the engine cover but I'm not 100% sure (especially in the rear). What you think?
matt_s
matt_s
Re: McLaren MCL33
Jackles-UK wrote:
11 May 2018, 19:34
The s-duct is about creating laminar flow along the top of the cockpit after the front bulkhead.
Air that is pushed up along the nose flows over the bulkhead and detaches, leaving an area of turbulence. The s-duct feeds directed air into this void to keep it attached. This is all some way aft of the area affected by the nose skirts.
Re: McLaren MCL33
You can see that between the DELL and the BR there was a flat spot before than is now rounder.
trinidefender
trinidefender
318
Re: McLaren MCL33
matt_s wrote:
11 May 2018, 22:47
Jackles-UK wrote:
11 May 2018, 19:34
Please no. It's not laminar flow. Turbulent flow is not detached flow. Very very few surfaces of the car have any sort of laminar flow. Maybe 20 to 30 percent of the front portion of the chord of the rear wing is laminar and only at certain speed ranges. The entire front wing is actually operating in turbulent flow.
Note that I did not say separation. They are not the same thing. Any airflow coming out of an S duct will be turbulent.
For reference here is a picture of a bug on a laminar flow section of a wing. The bug causes localised turbulent airflow behind it but does not cause separation.
roon
roon
412
Re: McLaren MCL33
Morteza wrote:
11 May 2018, 01:01
I see a nosecone like this and wonder what the casual observer thinks. Its design is 90% driven by the extensive ruleset for that area of the car. Trying to optimize parts for such verbose wording leads to this sort of contorted design (not a criticism). I wonder if people realize they're looking at legality-mobiles and not forms that are a pure expression of speed.
ScrewCaptain27
577
Re: McLaren MCL33
AMuS
- Serj Tankian
