Ferrari SF23
S D
Re: Ferrari SF23
codetower wrote:
04 May 2023, 20:28
Vinlarr89 wrote:
04 May 2023, 20:08
Too and bottom are different no?
I believe it's an optical illusion due to the angles. If you look at the top image post as well, they look very similar. If there is a difference, it's extremely minor.
It's probably the angle but in the bottom photo the top wing seems to have a more pronounced outside curve and less pronounced inside curve. Where do we find the submissions for the official changes?
scuderiabrandon
111
Re: Ferrari SF23
codetower wrote:
04 May 2023, 20:28
Vinlarr89 wrote:
04 May 2023, 20:08
To me the top wing's upper most element looks backed off a bit more on the outboard section and slightly more cranked in the mid span, but as you've mentioned could just be a matter of camera angle.
scuderiabrandon
111
Re: Ferrari SF23
S D wrote:
04 May 2023, 21:16
codetower wrote:
04 May 2023, 20:28
Vinlarr89 wrote:
04 May 2023, 20:08
If I'm not mistaken it only gets published tomorrow. I usually just wait for Albert Fabrega to post it on twitter.
Andi76
Andi76
476
Re: Ferrari SF23
gordonthegun wrote:
04 May 2023, 18:03
The image that usually inaugurates a race weekend shows that nose and FW are the same, so upgrades are not in this area :wink: :
https://cdn-8.motorsport.com/images/mgl ... s-o-1.webp
In my opinion, they don't really look the same, even if the angle makes it a bit difficult. But especially in the area next to the nose itself, the upper flap does look a bit different and the shape seems to be a bit different in the outer area as well. The Italian media also report about changes to the front wing
gordonthegun
261
Re: Ferrari SF23
gordonthegun wrote:
04 May 2023, 18:03
Look at how much more readable the names of the sponsors are in the bottom wing.
The angle is so different that even the wings seem different.
The Italian media talk about upgrades to the diffuser.
Xwang
Xwang
29
Re: Ferrari SF23
gordonthegun wrote:
04 May 2023, 23:21
gordonthegun wrote:
04 May 2023, 18:03
The bottom one is only pitching more down in the support used to store them AFAICS.
falonso81
Re: Ferrari SF23
No Ferrari pictures yet? Are they hiding the upgrades? 🤣
Farnborough
Farnborough
152
Re: Ferrari SF23
gordonthegun wrote:
04 May 2023, 23:21
gordonthegun wrote:
04 May 2023, 18:03
Agree, its lens effect doing that.
With a lens (likely a short range zoom) moved into wider angle the image is distorted a little like a mustache along top, look at lines in buildings there. Opposite in bottom to pull the central section toward image sensor. Top wing paasses through the lens centre with very little aspect/distortion change at all, making the two wing look different when there's no change.
It's called rectilinear distortion, and often referred to as "breathing" when it changed geometry as the photographer zooms the lens from one end to other.
The two wing would have to be in exactly the same position in frame to judge them competently.
gordonthegun
261
Re: Ferrari SF23
Also the end of the floor seems the same.
Venturiation
Venturiation
103
Re: Ferrari SF23
Single pylon and new under floor upgrade ( not visible)
gordonthegun
261
Re: Ferrari SF23
hape
hape
Re: Ferrari SF23
bluechris wrote:
03 May 2023, 12:29
Also a stiffer suspension will not make the tyre problems bigger because the car will loose grip in slow and medium corners more easily? All ready Ferrari is much stiffer than RedBull.
I'm not sure it's allowed by rules but it would be possible to have two different suspension/damper systems on one arm. That is, one resulting force due to acceleration is pulling the wheels down (car upwards) very slowly, heavily dampened. This would make up for the downforce that pulls the car down further and further with increasing speed.
The other suspension/damper set is for absorbing bumps.
GrrG
86
Re: Ferrari SF23
Ferrari floor and diffuser upgrade
falonso81
Re: Ferrari SF23
So, no revised sidepods here?
S D
Re: Ferrari SF23
falonso81 wrote:
05 May 2023, 18:00
It seems not for the race. However we may see something in FP.
