2026 McLaren Mastercard F1 Team
Def
Def
Re: 2026 McLaren Mastercard F1 Team
_cerber1 wrote:
20 Feb 2026, 15:23
Def wrote:
20 Feb 2026, 15:18
There is no rear axle, so there is a problem.
https://fastpic.org/view/127/2026/0220/ ... b.jpg.html
Where is the rear axle visible?
_cerber1
299
Def wrote:
20 Feb 2026, 15:26
_cerber1 wrote:
20 Feb 2026, 15:23
Def wrote:
20 Feb 2026, 15:18
Usually, to remove the rear axle, you have to remove the rear fender.
Macklaren
Macklaren
very few other drivers out. so seems like everyone is waiting for more representative conditions
FittingMechanics
FittingMechanics
They really looked very casual. No rush. So either they can't fix it quickly and are waiting for something or they have time.
Def
Def
_cerber1 wrote:
20 Feb 2026, 15:29
Def wrote:
20 Feb 2026, 15:26
The photo above shows that there are no rear axles, but there is a wing.
McFAN
McFAN
21
Def wrote:
20 Feb 2026, 15:18
McFAN wrote:
20 Feb 2026, 15:03
https://www.skysports.com/f1/live-blog/ ... eblog-body
A few minutes ago on sky's live-blog
Ruth Buscombe, at the McLaren garage:
"It is all fairly quiet. Some setup work is happening at the front, some tape being applied to the rear.
"I wouldn't expect to see Lando Norris out particularly quickly but it doesn't look too panicked."
Garage doesn't seem to be cordoned off.
https://liveblog.digitalimages.sky/lc-i ... 8d1b47.png
The garage is usually closed off when significant work is being done on the car,
But you may be right.
Macklaren
Macklaren
car looks fine
*technical issue confirmed though car looks to be going out imminently
CjC
CjC
Sorry guys. My fault the car isn’t out. This afternoon is the one and only time that I’ve been able to watch any testing live.
Just a fan's point of view*
FittingMechanics
FittingMechanics
Bernie Collins reporting that McLaren noticed a issue in data during the lunch break, decided to check and made a precautionary change. She is speculating that they made a water cooling system bleed/change. The engine was fired up recently. Looks like they may be on track in 10-15 minutes.
Ground Effect
CjC wrote:
20 Feb 2026, 15:42
Not your fault, that honour goes to @Darth-Piekus, he jinxed it, bragging about McLaren's reliability compared to others. Next thing you know.... :lol:
_cerber1
299
The team is the leader in terms of the distance covered in the tests, and it is possible that the main program has already been completed and only minor checks remain. Therefore, they are not in a hurry.
Xero
Always good to find faults like this during testing. Going through the whole test with no reliability issues leaves them open to rear their ugly head at a race weekend.
Darth-Piekus
-1
Ground Effect wrote:
20 Feb 2026, 15:47
CjC wrote:
20 Feb 2026, 15:42
Ok we had one single problem in 3 tests.
SoulPancake13
SoulPancake13
Darth-Piekus wrote:
20 Feb 2026, 15:51
20 Feb 2026, 15:47
CjC wrote:
20 Feb 2026, 15:42
not to be pedantic, but mclaren had a hydraulic problem on the second day of their barcelona test ;)
Darth-Piekus
-1
Two problems out of 3 tests. The other 3 of the big 4 had much more problems.
